Old 07-19-2010   #1
sammy
Default help on keys
i messed up and lost the keys to my car . is there a way i can get copys from a dealer and if so how does one go about doing it .thanx for any help you can provide
Old 07-19-2010   #2
Default Re: help on keys
Any Chevy dealer can help you.
Bring your original set and a copy of your registration (just in case).
Old 07-19-2010   #3
sammy
wish i could bring the original set ,but only had one set and they are gone now , do i have to go out and buy new locks or does ,can the dealer set me up with new keys ?????????????
Old 07-19-2010   #4
You will need proof of ownership and the VIN. A Chevrolet dealership can get the VATS key code from your VIN number.
Old 07-20-2010   #5
sammy
is the vats key code the code for the little pellet on the key or does it include the info to reproduce the whole key . i had previosly got the correct blank keys with the right pellet code for both my zr1s. just hadnt gotten around to getting them copied . i am getting copies made for my 92 tomarrow .i have the correct blank for the 90 but nothing to make a copy from ??/ thanx for the info so far.i guess i will fess up as to where i lost the keys , at one of nevadas finest brothels. guess more than my business went into the hole
Old 07-22-2010   #6
phrogs
phrogs's Avatar
Call the dealer and see if they can still get the key codes.
im not sure if they still have the stuff from back then.
I do have an ignition switch with key if you need one
Id sell if not to hard to get in and swap them then you can get the key cut with the correct pelet for your car with this lock cylinder.
the code has nothing to do with the switch its all in the BCM.
JOHNNY P
Currently own
Old 07-23-2010   #7
The resistance of the little pellet in the key is what matters. There are 15 different pellets.
If you already have the correct blanks, you're over the biggest hurdle. The VIN should provide the Dealer with the key cut info.
Old 07-23-2010   #8
sammy
guys tahnx for all the insight . i guess i am glad i have the right pellet blank. i will try and call the chev dealer in reno tomarrow and will let everyone know what transpired .
Old 07-23-2010   #9
xlr8nflorida
xlr8nflorida's Avatar
So....how do you get the blank key with the correct little pellet in the key
Lets say I lost my keys and only have the VIN and TITLE (Registration) to the car. Lets say I have no blank keys with correct pellet
If I present VIN, Registration, Photo ID (Drivers license) to the Dealer.......
A Dealer can get (has on hand) the key blank with the correct pellet from the VIN?
Same goes for Key Cut information?
They will charge you big time to get pellet code. You take your existing key to radio shack and they can tell you the code, you cross reference the ohms to find your number which is between 1-15. You can buy extra blanks for 25 dollars pair then have locksmith cut them for a few bucks as long as you have original set of keys. Otherwise it will easily cost you 200 at dealer.
Old 07-23-2010   #10
John Boothby
John Boothby's Avatar
Wink Re: help on keys
I had my dealer check the resistance of my key (no charge) and I wrote it down for future reference. I also ordered a blank key with correct resistance from MidAmerica or Eckler's. I believe it was about $14. I would suggest this to all who have not done this yet. I was a boy scout many moons ago and still remember the motto: "Be Prepared".
John Boothby is offline   Reply With Quote
