Old 07-12-2010   #1
Topfuel
Topfuel's Avatar
Default Twin turbo LT5 engine for my Camaro
I decided to start a new thread just on the engine. After this engine is all done If there is a demand for it I am going to write a small article on what I have learned about this engine its good points, bad points, and things to watch out for . I thank all the good people that gave me info on this engine as I was putting it together. You all will be mentioned When I write this article on the LT5 thanks everyone enjoy the pics
Here is the left side the red dykem is so I know where the bottom of the piston is just a helping hand
This is the right side notice the head studs Top of the line ARP 2000
The head after new valves and surfaced
The other head
My baby at 18 months helping dad put her first LT5 together she is turning the crank
After taking the timming chain tentioners apart to reseat them before installation
Well It looks like I can only post six pictures at a time and I have 16
Topfuel is offline   Reply With Quote
Old 07-12-2010   #2
Topfuel
Topfuel's Avatar
Default Re: Twin turbo LT5 engine for my Camaro
so Here is another 6
Close up view of the tentioner snap ring that has to be compressed to assemble it
Another view of the snap ring
Using electrical tape to compress the snap ring so I can assemble the tentioner
The bottom of the assembled engine from the front showing the ARP main bolts on 1 3 5 mains magic marker is so I know the torquing sequence and the amount to torque it to
Side view of the bottom end look at those nice aftermarket rods again the red is so I can read what rod is where
Close up of the tool I made to time the crank to the cams
Old 07-12-2010   #3
Topfuel
Topfuel's Avatar
and all the rest
picture of the primary timming chains
Here is the primary chains
Picture 1 of the engine almost done still need to work on fuel spark and front drive stuff
Another picture top view
I dont have the water inlets and the valve cover on for good yet and the top intake but was getting excided and need to take pictures.
Old 07-12-2010   #4
Belsy
Belsy's Avatar
Great pics! Always good to see this powerplant being used outside of GM factory specs as you will surely find better ways to hook up and use more efficient ways to cool, feed and breathe this engine. as parts become harder to find the ingenuity used here will help all of us!
Good luck with your venture and please keep us up to date with your discoveries as you get it to work.
Belsy is offline   Reply With Quote
Old 07-12-2010   #5
Wow that sure is LT5 porn! Thanks for sharing with all of us!
Sure wish I could have been a fly on the wall to watch the assembly.
I hope you have a ton of fun when you're finished!
Old 07-12-2010   #6
Kevin
Kevin's Avatar
DO WANT holy **** that's hot
Old 07-14-2010   #7
Topfuel
Topfuel's Avatar
[QUOTE=tomtom72;93579]Wow that sure is LT5 porn! Thanks for sharing with all of us!
QUOTE]
I put the engine together and apart several times just don't want to do it again. First time with this motor. Checked and checked oil clearances mains and rods, filed rings for hours questioned myself many times and called people to make sure doing things right or what seemed to be right. Got main bearing clearances at 1.9 to 2.1 thousands a little loose by the book standards but by every engine I have built those are perfect. Juggeled rods around till got them all at 2.1 but rear set at 2.3 and 2.4 thousands guess they are the furthest away from the oil pump and crank had worn a little bit. But I think I am going to use 10-40w or 15-40w oil. Still have to build the remote oil filter set up and drop that ugly GM upside down oil filter assembly. also going with coil on plug ignition system WOW 1999 to 2004 LINCOLN CONTINENTAL DOHC ford coils fit like they were made for this engine DC512 is the part number.
Old 07-15-2010   #8
Belsy
Belsy's Avatar
Have you devised a plan for the PCV / breather system? Are you plugging the plenum coolant from inj. housings and what are you planning for ECM and fuel pump adaption? These are all areas where improvements are welcome. Good Luck
Old 07-16-2010   #9
Topfuel
Topfuel's Avatar
Not sure about PVC system thinking leave it alone and add another check valve and a "t" so under boost it vents to the air. Crankcase pressure is a BIG problem with a boosted engine. I am not pugging the water from the inj housing just cut them off at the housings and welded AN-16 fittings on them for the water lines to the radator. I will post a picture of my in tank fuel system. It is made by FORE presision fabrication it has 3 walbro 255lph in tank fuel pumps teed together and then using a weldon fuel pump regulator referanced to boost pressure. Injectors are ford motorsports 42lbs per hour injectors and the whole system will be managed buy F.A.S.T. XFI coil on plug ingniton system and F.A.S.T. Xfi ECU and a F.A.S.T. TCI transmission control unit for the 6 speed auto. With twin touch screen dashesto display all the info and to tune and do data acuasision . So talk about a wiring nightmare.
Old 07-17-2010   #10
Mike,
It looks really great!! I especially like the personalized touch.... "Sherbring Racing". How did you go about filling the OEM lettering & emblem recesses?
BTW, I found a new balancer that had about 1/4" machined from the engine side of the hub.. Might be just right for that trigger wheel we were talking about.
Jerry
