![]() Join Date: Feb 2006
hows this? Luis |
after clean-up
Wow - night and day, geat job.
![]() What did you use - wire brush? media blast? Question is - how to keep them looking that way?
[SIGPIC][/SIGPIC] __________________ 1990 Corvette ZR-1 #2824 4.10's, Custom PROM, Flowmaster, Top End Port NCRS BC Chapter |
![]() Join Date: Dec 2005
Looks great! I'm curious to what you used also.
thanks guys !!!
well.... 1st - 3m brake clean - spray 2nd - aluminum mag wheel cleaner - spray 3rd - agitene solvent from grainger, like what we use in a parts washer. soaked, then wire brushed crevices (w-brass brush w-handle). stuffed a shop rag in the cyl. bore to keep from scarring it any. 4th - lps electro contact cleaner - spray 5th - brake clean again, aluminum wheel cleaner again 6th - touched up with a 10" "fine" wire brush wheel set-up on pedestal grinder. 7th - contact cleaner again. also chased the threads: e-brake hole, bleeder, line. took a lil while, but came out great to me. yea, how do I keep em that way????? ![]() thinking I should clear laquer, or satin spray em, but not even sure it would last. ![]() Last edited by FULLPWR; 06-04-2010 at 11:19 PM. Reason: added thanks |
I was thinking clear satin laquer followed by lots of spray on wax (I know the wax it makes a huge difference in keeping my wheels clean)
What are you going to do about the fronts? Upgrade to C5 calipers?
![]() Join Date: Dec 2004
![]() ![]() You da Man Luis! ![]() Now write up the steps, taking it apart & going back together, including any "gotcha's" that maybe lurking and send this in to our newsletter....aren't I great at spending your time!? ![]() ![]() ![]() Tom
#8 | |
that spray on wax...is that like the detail spray quick shine?? what do you use? man I dont know about the fronts, I have bought rebuild kits for them, but after listening to you guys i want to do that but but but.......I still have to get her exhaust better, and tune so i'm stuck with probably just rebuilding them for now. I just have it jacked up in back for the rear stuff, and was going to get all that repairs done then tackle the front calipers, cuz i wanted to flush all the old fluid out as completely as possible. I do have ceramic pads for the fronts i bought to put on also. I just need to win that dam lotto ![]() kinda sucks that calipers are gonna look good and the rest under there needs alot of cleaning, i need 4 arms and 8 eight legs and lotto ![]() |
#9 | |
I will record what I am doing, but im sure others might have different & way better methods,and access to better tools and/or chemicals. I'm just a mex/italian STALLION ![]() ![]() gotta go get under z...later..... |
#10 |
OK I am bringing you mine now!
