05-26-2010 | #1 |
A question about the Tech 1 Scanner.
Ricky was nice enough to let me borrow his Tech 1 scanner for my ABS problem but cant quite figure out how to use it.I plug it into the cig lighter,plug it into the underdash port,type in year 1991 and scroll down and select stored trouble codes and it asks for the ABS adapter.Am I missing something here?
05-27-2010 | #2 |
Re: A question about the Tech 1 Scanner.
Jeff, this is just a fwiw in that I'm not positive it applies to a Tech1 scanner.
On my snap-on scanner there are software modules that I plug into the scanner to do trouble shooting on the different vehicle systems. I have a general GM cartridge and a GM engine trouble shooting cartridge in the scanner when I do the DTC's for the motor controls. If I do my abs system, I need the general GM cartridge + the specific ABS cartridge plugged into the scanner before it will do any diagnostics. Now if I want to just pull ABS trouble codes, I use my Gordon jumpers. However, if I want to run any of the tests I have to use the scanner with the ABS cartridge in the machine. I am fairly sure that the Vertronix Tech 1 and Tech 1A scanners are the same as I keep looking for one on e-bay with a fairly complete cartridge library as the older software is sometimes hard to find. Tom
05-27-2010 | #3 |
I think the problem is I dont have the ABS cartridge.
05-27-2010 | #4 |
I know that all the Tech 1 & 1A machines I looked at on e-bay used a software cartridge system similar to what my snap-on scanner uses....so yes if you don't have a cartridge labeled ABS, then you need to see if you can get one.
05-27-2010 | #5 |
You need the ABS Brake cartridge p/n TK03030B for, I believe, 1988-93. Good luck finding one, I have been looking for a while. There are TK03030 cartridges all over, but I can't find the "B". Anyone out there have one would like to sell, let me know.
JB 1990 #148 Red/Saddle Haibeck AYBKG5 Chip/RC Engineering/Flowmasters/K&N/Samco/Fuzzy Dice :cheers: |
05-27-2010 | #6 |
John,
I recently checked the ABS system on my car with my Tech 1 and the first thing that comes up is the "adapter" item you mentioned. This is not the software cartridge but an additional adaptor that plugs into the end of the regular Tech 1 connection that goes to the ALDL connector. From my memory this additional adaptor correctly connects to the ABS pin out on the ALDL connector. I would check that first as I am not sure your issue is the software at this point. Could be wrong, but I distinctly remember that item poping up as well. Hope that helps. Troy
Troy Marquis 68 L-89 #9876 - Under Restoration 69 L-88 #21214 - L-88 Tribute 70 L-46 #9516 - Top Flight 71 LT-1 #2638 71 LT-1 #5172 - Canadian Export - Top Flight 71 LS-6 #15133 - Canadian Export - Under Restoration 90 ZR-1 #338 - Restored 90 ZR-1 #890 Project Phoenix 91 ZR-1 #1255 - Triple Crown Winner 69 Firebird Project: w/ 69 L-89 Motor #24390 16 Z06 Admiral Blue/Red Interior (1 of 2) - Sold |
05-27-2010 | #7 | |
http://cgi.ebay.com/ebaymotors/TECH-...motiveQ5fTools http://cgi.ebay.com/ebaymotors/GM-Ve...motiveQ5fTools
GOLDCYLON - 91 ZR-1 #2014 GOLDCYLON - 90 ZR-1 #2794, 4L60e (Formerly Schrade's) GOLDCYLON - 11 CTS-V Arizona State Director 91 WHITE/BLACK #2014. 380 P&P&PCed,Ported Heads, Jeal Long tubes, Corsa Exhaust/FIKSE FM-5s /LED TLs, LED Headlights, Front Wilwood 6 piston narrowlite calipers and rear Wilwood caliper street shop mod,CNCed Coolant Pipes,TPI Cvr,Filter cover,Stainless Bolts, DRM/DOM PROM /ZFDOC mod build #102,DRLs,BMAD with stainless Debris Screen,Coplan Air Blaster, Pioneer APP Radio 4,Brey-Krause HB,Sub Bar,Fire extinguisher seat mount,DRM Coilovers,LEDs everywhere,Compass mirror (orange),V1 DIC hidden display, Homelink sun visor, Carbon Fiber top x3 and APSIS Carbon Fiber interior, APSIS CF Steering Wheel/NAPA Leather, Banski trailing arms, Guldstrand front suspension,urethane bushings from Prothane (total suspension) ZFDoc drive shaft safety loop, raptor shift light (orange),AO engineering louver front plate, Console seat cushion, 96CE seats with black custom Sheepskins, ss billet catch can,Viper remote entry/alarm,Cragar Rear Louvers,LED side louver lights, Dewitts Radiator with SPAL fans and a Woods 160 T-Stat 90 RED/BLACK #2794. 4L60e Automatic Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless Headers, Corsa Exhaust, SAN Secondaries and Haibeck PROM, Exotic Muscle Coil overs, LED Interior Lights, LED Tail Lights, LED Headlights, 94 Sport seats with black custom Sheepskins , Cragar rear louvers, GS Front calipers, Banski Trailing arms, APSIS Carbon Fiber steering wheel, Front and Rear Baer Eradispeeds, DRLs, Guldstrand front suspension,urethane bushings from Prothane (total suspension), Dewitt's Raditor with Dual SPAL fans and a Haibeck 170 T-Stat 11 RED/GREY CTS-V Last edited by GOLDCYLON; 05-27-2010 at 09:18 AM. |
05-27-2010 | #8 |
you need the mass storage cartridge in tech-1 and the bosch ABS adapter plugged in to port under dash.plug tech-1 into adapter.
05-27-2010 | #9 |
To plug into the ALDL you need the 12/14 pin adaptor TA01140. I don't think that you "need" the mass storage adaptor unless you are storing data to download into a computer.
05-27-2010 | #10 |
By the way, whats going on with your ABS. I ask because I had a "Service ABS" light on my DIC and it turned out to be the "Lateral Accelerator" behind the radio in the dash. Pretty easy fix and not expensive!
