Go Back   ZR-1 Net Registry Forums > C4 ZR-1 > C4 ZR-1 Prototypes
Old 05-23-2010   #1
1989ZR1#74
Default Well I found out the VIN for the Record car
For those of you that atteneded the proto seminar, you heard me ramble about not being able to confirm the VIN of the record car... Well I have the answer:
As I originally though it is vin #45..
I had the archives search the build sheets for EX5669. They found it written on a copy of #45. The problem is I bought a copy of that sheet at the Gathering and my copy did not have EX5669 on it. Aparently there are sometimes several different copies of the same build sheets with different things written on them. So mystery solved. Now onto Snake Skinner II
1989 ZR-1 #04 Pilot, Advertising/PR Campbell-Ewald S9YKH1
1989 ZR-1 #58 LT5 only
1989 ZR-1 #74 Unreleased Production / PR Dept 9PR110
NCRS #3,182 SACC #2,420
Member Corvette Museum
Corvette Forum: "ewjxn"
2009, 2010 Gathering Attendee
1989ZR1#74 is offline   Reply With Quote
Old 05-24-2010   #2
Blue Flame Restorations
Default Re: Well I found out the VIN for the Record car
Do you have the vin for the "record" press car? If not, it is 1989 #13.
1990 ZR-1 #444 Convertible
1990 ZR-1 Black #966
1991 ZR-1 Quazar Blue #296
1957 Duntov SS Project
Old 05-24-2010   #3
1989ZR1#74
Brett, Yes I had that one. Hopefully that car will "surface" someday and we can see it again.
Old 05-25-2010   #4
vettebrett
It will be a long time and probably a court case to get that car out of a garage and from underneath that car cover. i really wish it would surface but I know it will not be an easy fight.
'89 BLK/BLK
[B][URL="http://www.corvettechallengeregistry.com"]Corvette Challenge Registry[/URL][/B]
[B]Morrison Race Car Registry[/B]
[IMG]http://i39.photobucket.com/albums/e191/brettrichmond/C1.jpg[/IMG]
[IMG]http://i39.photobucket.com/albums/e191/brettrichmond/brettvette12.jpg[/IMG]
vettebrett is offline   Reply With Quote
