05-15-2010 | #1 |
compatible parts from normal C4's
Hi all
Generally speaking will typical Zed service parts such as... Tie rod ends, sway bar links, rubber bushes, ball joints, suspension and steering components, wheel bearings, brake pipes and cables, rotors, calipers, brake pads (for 13")....etc etc be identical to parts from normal C4's of 90 to 95 vintage Now that lve sorted out my shipping to UK....lm going on a major service parts buying spree but want to get the most ecconomical solution....However it often seems that if ZR1 is written next to the part description it also seems to put the price up. So lm looking to get general '' C4 corvette'' parts that do the job l just want to know what kind of general item areas are generic Thanks to all Dave |
05-15-2010 | #2 |
Re: compatible parts from normal C4's
all the above parts you listed are the same as a regular C4
