Old 05-13-2010   #1
Default Looking to borrow,rent a Tech 1 scanner.
Dont need it anymore.
Old 05-13-2010   #2
Aurora40
Aurora40's Avatar
Default Re: Looking to borrow,rent a Tech 1 scanner.
You can pull ABS codes with the same paperclip trick, I believe. It's simply a different pinout you ground. I will check the FSM later if no one else has replied with the procedure.
