Old 05-12-2010   #1
VetteMed
Default Secondary vacuum pump FS
Used, removed from '91, is not the original, but apparently a recent service replacement. Excellent condition, works 100%. I will include the vacuum hose that runs to under the plenum.
$95 shipped.
Old 09-10-2010   #2
TN90-ZR1
TN90-ZR1's Avatar
Default Re: Secondary vacuum pump FS
Do you still have the pump by chance ??And do you know if it would fit a 1990. Seems as though I've read somewhere they're different somehow. Thanks
TN90-ZR1 is offline   Reply With Quote
Old 09-10-2010   #3
VetteMed
Still have the pump, but I have to dig to find it. 90 used a different connector, from what I have read... you would need to change the connector on your harness to utilize this pump.
