#1 | |
![]() Join Date: Dec 2003
I posted the following as a response on another thread under Parts for Sale and Wanted, but thought it should also be here, so It's copied below.
Jerry,why tool up for 2 different gaskets just do the RH wouldn't it be a liittle easier/cheaper?
Hope all goes well. Pete
#3 | |
Would be a little cheaper, but in the long haul, not enough to possibly be perceived as "half-azz", even though it's not. Straight forward replacement, LH & RH, seems the best way to inspire customer understanding and product confidence.
#4 | |
any possibility of having a multi layer steel gasket mfg'd, for close deck purposes Jerry?
Not by me. I've looked into it extensively with Cometic. VERY expensive proposition. LT5 is already a limited market & closed deck LT5's.....you can count on 1 hand.
jerry you are awsome, bill b. looked at some of your gaskets that i had the other day and said they are first class all the way . that you for caring about our cars like you do . we are all so very lucky
UPDATE, 30Jun10:
Tooling is finished & 2 sets of gaskets for inspection & testing are being shipped. If they pass the fitment test & visual inspection, then a set will be installed in an engine for 2 days of engine dyno running & subsequent tear-down for inspection.
Awesome, Jerry!
#9 | |
![]() Join Date: Dec 2004
#10 |
![]() Join Date: May 2010
Is there any new developments to availability of head gaskets?
http://www.cometic.com/news-details.aspx?id=56
Craig "ZR-1 NO KA 'OI" "ZR-1 ICHIBAN" 1995 #228 Black/Black with Dunn Heads ZR-1 owner since September 2003 ZR-1 Net Registry Founding Member #0074 NCM Lifetime Member #2048 ![]() |
