![]() Join Date: Jul 2007
I found the Power antenna bracket dangling under the car yesterday..
What Size nuts are used where the mount bracket attaches at the bumper/fender seem Also what size are the bolts on that go into the bottom of the antenna to hold it to the bracket?
![]() Join Date: Dec 2007
Ill be home all day if you want to stop by and look....
I might.. we will see how the day goes. I can SEE them and all, just was hoping to know the exact sizes
![]() Join Date: Mar 2007
Are these the 8mm heads with the large washer?
about 13mm long
you tell me.. I NEED them as I don't HAVE THEM
The ones I took off the car, and are sitting on the ramp are 8mm head, 13mm, long and calipers show about 5mm width, 20mm washer.
#7 | |
those thread in the bottom of the power antenna unit? that sounds right.. was there a ground strap on one of those too?
![]() Join Date: Feb 2006
There's a ground strap at the top and bottom. The top one makes removal a b*tch unless you just rip it off because you have to remove the leftmost taillight to get to it.
#9 | |
On the bottom one, is it sandwiched between the bracket and antenna body? or another bolt?
#10 |
The bottom strap is bolted to the bracket fastener - but not sandwiched.
The FSM page 9A-21 shows the strap fastened with one of the bottom bracket bolts.
