Old 03-17-2010   #1
zrwhat
zrwhat's Avatar
Question Flywheel and Pressure Plate Bolts:FIDENZA
Where is a good source for Flywheel and Pressure Plate bolts when changing over from a Dual Mass to a Fidenza on a LT-5?
What exactly are the difference in their lenghts?
Pressure plate bolts are the same, correct, FW need to be longer, correct?
Thanks.....
zrwhat is offline   Reply With Quote
Old 03-17-2010   #2
Default Re: Flywheel and Pressure Plate Bolts:FIDENZA
I believe its 7/16 1.25" bolt for flywheel, I ended up at ACE hardware.
Old 03-18-2010   #3
tf95ZR1
tf95ZR1's Avatar
Good thread to read:
http://www.zr1.net/forum/showthread....a+bolts&page=4
Also SRP products sells a set of bolts.
Old 03-18-2010   #4
Jagdpanzer
Jagdpanzer's Avatar
I have an extra set of longer flywheel bolts you can have.
Old 03-18-2010   #5
Due to sourcing of Ace bolts, I was advised to avoid using them on the flywheel even if they are Grade 8s.
Old 03-18-2010   #6
Guy in Freeport builds motors for drag cars and tractors(pulling) told me they are fine.....he uses them..... Guess I will find out.
Old 03-18-2010   #7
OK! I'll help push your wheelchair.
Old 03-18-2010   #8
Looked on line, no references to bolt faliures using their stuff. I doubt they are going to put themselves out there for that kind of liability over a 1.50 bolt.
Dist is Hillman
If anyone knows of a first hand example, please share.
