Old 03-04-2010   #1
White Bullet
White Bullet's Avatar
Default For Sale DRM E-PROM 91
DRM E-PROM for 91 LT-5 $85.00 including standard shipping anywhere in the USA (I will not ship internationally). The chip was in the car when purchased and is in working condition. I do not know anything about the program. It was replaced with a Haibeck chip. Contact me for payment options.
1991 ZR1, White/Red.
Old 03-04-2010   #2
Default Re: For Sale DRM E-PROM 91
You have a message
Old 03-04-2010   #3
zrwhat
zrwhat's Avatar
WB,
Did you notice much difference between the DRM e-proms and the Haibeck e-prom performance wise?
Do Tell!
zrwhat is offline   Reply With Quote
Old 03-04-2010   #4
White Bullet
Originally Posted by zrwhat View Post
WB,
Do Tell!
My car is a daily driver and it sees no racing. With that said I have noticed two differences. One is the engine idles smoother and the other is under full throttle the power band seems to be broader. I got the Haibeck chip for the updated stock calibration and the cooling fan management. I have moved to warmer weather area and did not like how the DRM chip ran the cooling fans. I believe that is no different than the stock GM chip.
Old 03-04-2010   #5
The "tuner" calibrations do nothing for things like part throttle operation. They basically look to optimize WOT when calibration goes Open Loop. It takes quite a bit of time and effort to get part throttle correct. In addition, there's always the emissions issue. If you compare stock cals to "off the shelf" tuner cals, you'll find very few changes and only in the areas I've outlined.
Old 03-09-2010   #6
White Bullet
Item sold. Thanks Dynomite. Your package has been sent.
