Old 02-21-2010   #1
Jagdpanzer
Jagdpanzer's Avatar
Default Where to find a Torque Honing Plate
Starting to locate sources for the special tools I will be needing to assemble the LT5 stroker motor I've got in the works. To go the 402 CID route with the 4.0" crank I have 4.0" liners will be required. Anybody have a good suggestion on where I can borrow, rent, or otherwise acquire reasonably a 4.0" torque honing plate for an LT5? Right now I'm thinking of using an local motor machine shop that is well versed in automotive engine liner installations but unfortunately they do not have a LT5 torque plate on hand for finishing the liners once they are installed in the block. Found a source for a BJH plate here: http://www.cylinderheadsupply.com/6604.html
No doubt a nice plate but a lot of $$ for just one engine build. Would prefer to spend the money elsewhere if possible.
Thanks,
Phil
Old 02-21-2010   #2
jonszr1
jonszr1's Avatar
Default Re: Where to find a Torque Honing Plate
you might ask flyn ryan if he knows someone
Old 02-22-2010   #3
Pete
Pete's Avatar
Hi Phil
For that price you might be better off sending the motor to someone like Marc or Ryan to have it honed and shipped back to you.
Just an idea.
See you at BG
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 02-22-2010   #4
Polo-1
Jeff and I bought one or 2 for the shop thats doing the work on my 402 and 368. At least i think Jeff went in on part of it
Old 02-22-2010   #5
Jagdpanzer
Jagdpanzer's Avatar
Thanks Kevin, PM sent
Old 02-25-2010   #6
Jagdpanzer
Jagdpanzer's Avatar
I found a local machine shop with a water jet table.
Can anyone help me out with a cad drawing of the cut out in either dwg or dxf format? My guess is a head gasket would do for a pattern.
Old 02-25-2010   #7
secondchance
I use AutoCad Architecture 2010. Files are in .dwg or can be .dxf.
Give me a good instruction and I can do it for you.
Old 02-26-2010   #8
Jagdpanzer
Jagdpanzer's Avatar
Thanks Yun, I will measure it up and put a sketch togther over the weekend.
Old 02-26-2010   #9
Phil,
Let me see if I can hustle you up a .jpg of a drawing before you start on it. Dimensions are metric.
Dwg sent.......
Old 02-26-2010   #10
carter200
carter200's Avatar
Phil,
Dwg sent.......
Jerry, would you mind sending me a copy of that drawing, too. Thanks
95 ZR-1
BLK/Gry
#392
LT5 Reg# 868 *RIP*
ZR1NET Founding Mem #155
