Old 01-11-2010   #1
Eric870
Eric870's Avatar
Default WTB: 1990 Radio Bezel
WTB: a 1990 Radio/power key console. Looking for a New one....
Eric870 is offline   Reply With Quote
Old 01-12-2010   #2
Jeffvette
Default Re: WTB: 1990 Radio Bezel
Unobtanium. I don't think I have seen a new one ever. Just high quality used ones all the way down to garbage.
Trying to fix the led hole that is in yours?
Old 01-12-2010   #3
bdw18_123
Yeah, you probably won't ever find a new one of those. And if you do, whoever has it will probably want like $300 for it.
I need one of those too, as mine has the radio hole hacked up. I'd settle for a decent condition used one, but even those are hard to find. You would think that with over 3,000 90's made, they would be a little easier to find.
[IMG]http://i13.photobucket.com/albums/a292/bdw18_123/_zr1netforumsigphoto.jpg[/IMG][B]
1990 Corvette ZR-1 [/B][I]
White/Flame Red, #2299, mostly stock, 144K miles.[/I]
-Cams timed to the '93-'95 405HP LT5 stock timing.
-IAT sensor relocated to below front bumper.
-Haibeck hoops installed in airduct.
-OBX cat-back exhaust.
[COLOR=DarkRed][B](SOLD - December 2012 [/B][/COLOR][COLOR=DarkRed][B]:hello:)[/B][/COLOR]
1993 Corvette Coupe
Black/Black, 6-speed
(SOLD - October 2009 :hello:)
Old 01-12-2010   #4
Yeah I was going to chime in here when you said you were looking for a "new" one as well. Keep looking im sure one will turn up. I had the same problem were the previous owner had drilled in three sets of LEDs into the panel for some type of alarm system and cut the crap out of the radio area. It truely is a one year only bezel. Good luck
Old 01-12-2010   #5
Eric870
Eric870's Avatar
I figure this bezel will cost an arm and leg. Just hope someone has a nice one stashed they are willing to part with....
Old 01-12-2010   #6
Send a PM to Jim VanDorn
vandornjim is his handle. He may have one tucked away in the attic. Worth a shot. GC
Old 01-12-2010   #7
Eric870
Eric870's Avatar
"Send a PM to Jim VanDorn"
Thanks i will do that..I have bought some stuff from Jim before...
Question:
Will a non-ZR-1 bezel fit on a ZR-1? There is some on E-bay for $50.
Old 01-12-2010   #8
VetteMed
Question:
It will, but you will need to figure out how to mount the power key assembly. If you've bypassed the power key, then no problem at all
Old 01-15-2010   #9
phrogs
phrogs's Avatar
Cut a hole in it.
JOHNNY P
Currently own
Old 01-15-2010   #10
Not to be sticking my two cents where it don't belong,, but if it's just an LED hole you can fill it with plumber's epoxy. You know that stuff the hdw store sells in the tubes.
To make a smooth finish on the out side of the fill just get a stiff piece of cellulose like those clear file folders or a small piece of wax paper will work.
You want to use it as a dam to press the epoxy against. A bit of baby oil will work as a polishing lube to insure a glass smooth surface. The crinkle paint for our interiors that MAD or CC or ZIP sells is a great match...just shake the chit outta the can before shooting. I used it to re-shoot my bezel and it's a very, very close match.....not 100% but 95+%.
Or...I just had a bfo. Go get one of those :gel-coat repair kits. It comes with the acetate film for the smoothing operation and a polyester or epoxy mending filler compound.
to mask off the lettering I used scotch tape.
