Old 12-31-2009   #1
Sgreg
Sgreg's Avatar
Default FS: 1989-96/ZR-1 CORVETTE FIKSE FM/5 WHEELS
SOLD SOLD SOLD SOLD SOLD SOLD SOLD SOLD SOLD SOLD SOLD
Selling my stash of Fikse FM/5 wheels. I have two 11X17 inch fronts and two 11X17 inch rears. Prefer to sell together but I will separate. Price is $2000 for everything plus $125 shipping to lower 48. In my opinion, these are the most attractive C-4 wheels made and also are strong and light. I will throw in 4 of Carter's finished ZR-1 center caps. These wheels will fit all 89-96 Corvettes and ZR-1's without large caliper aftermarket brake systems. PM me if interested.
1991 ZR-1, Black, Black, # 541
Sgreg is offline   Reply With Quote
Old 01-01-2010   #2
Demps
Demps's Avatar
Default Re: FS: 1989-96/ZR-1 CORVETTE FIKSE FM/5 WHEELS
Okay, I have to ask:
1) Is the finish on all wheels the same?
2) Condition of all wheels?
3) Fitment of each pair?
a) offset
b) size
c) any measurements or serial #s
d) did you test fit the fronts? result?
thanks,
Ted
4) Interested in selling only the rear, proper ZR-1 fitment rims?
Old 01-01-2010   #3
Sgreg
Sgreg's Avatar
a) offset
b) size
thanks,
Ted
1) Rears are a polished and clear coated center and the Fronts are micro-polished; both are very shiny and I can't tell the difference without a three foot look.
2) Excellent no rim rash, inner and outer rims are perfectly straight and they have never been repaired.
3) They will fit a ZR-1 that has a standard brake (OEM) package. Large caliper 4 piston and 6 piston sytems will not clear.
4) Offset appears to be standard ZR-1
5) Both fronts and backs are 17X11 inches. 11 inch fronts fit. A plus is the 11 inch fronts are perfect for autocross.
6) Fronts are part # 2595 and backs are #3080 (as stamped in outer rim )
7) Yes, they fit. See #3 above.
8) Yes, I will sell fronts or rears or all four. I will not sell individual wheels.
Old 01-03-2010   #4
Sgreg
Sgreg's Avatar
Demps, You've got $2000 in pocket change !! You really need some of these. Buy 2 or 4. Hey, I am throwing in the redone Fikse centers made by the one and only Carter. I guarantee fit unless you are using a non GM C-4 brake package.
Old 01-03-2010   #5
Demps
Demps's Avatar
I was buying them for a car with Wilwoods. The Wilwoods fit behind A-molds. What keeps them from fitting behind your 11" fronts? The two different finishes bothers me. Can you send me some pictures--the face(s) of each and then lay then down and parallel to the ground of the bead area with the wheels laying flat side-by-side. thanks
Old 01-03-2010   #6
I may be interested in one of the rears as a spare wheel for the attic. If Demps does not want the set does anybody else out there need a spare 11X17 with the polished outer and clearcoated inner? Greg said he will let these go in pairs. LMK GC.
Old 01-04-2010   #7
Sgreg
Sgreg's Avatar
Demps, my Brembos fit under A-molds also. Fikse standard 89-96/ZR-1 wheel has nearly a three inch outer rim and 3 mm less offset. It will not clear the big brakes and sticks out a good 2 inches beyond the fenderline. Ugly situation. Note how narrow the outer rim is on the A-mold. Wheels are beautiful in general but not for you. When I say stock GM brakes, I mean Stock GM brakes. Don't know about C-5 brakes on a C-4. They might slide by. C-6 no.
Old 01-04-2010   #8
A1990
A1990's Avatar
If these fronts stick 2" past the fenderline, how do they fit correct with stock C4 brakes? Don't they still stick 2" past the fenderline?
Dennis Fierstein
90 ZR-1 #2562 Atomic-Z
ZR-1 Net Registry Chairman of the Board
ZR-1 Net Registry Treasurer
A1990 is offline   Reply With Quote
Old 01-04-2010   #9
Sgreg
Sgreg's Avatar
Dennis, my comment is confusing. I am assuming a spacer would be necessary to clear a big brake caliper. Depending on how big a spacer is necessary they will stick out accordingly. I should have said with my brake system (Movit) stuck out 2 " beyond the fenderline. Big Red Brembos require more room than a Wilwood I believe and my rotor hats act as a spacer in my system. Fits A-mold but does not fit aftermarket wheels without customizing. So... The result may be significantly better than I painted it. I hope so. Thanks for pointing out my misstatement. The Fikse ZR-1 wheel has a standard 53 mm front offset vs. the GM A-mold which is 56mm. While that difference is relatively small and has no effect on stock GM brakes, it can be magnified if a spacer is necessary. The question is in Demps case, does he need more than 53 mm for his offset to clear the Fikse's with his 6 piston Wilwoods ? Confused, I am !!!
Old 01-04-2010   #10
A1990
A1990's Avatar
I get it now. I think?? The will only stick out if you use the spacers to clear a big brake package, otherwise stock breaks and no spacers and they fit right.
I hope I have that right.
Good luck on selling them.
Dennis Fierstein
