12-15-2009 | #1 |
Oil Extractor tool
Any feedback on which one is best? Mityvac? I saw one review that said the seals will fail with synthetic oils. Which model is best?
12-15-2009 | #2 |
Re: Oil Extractor tool
I can't comment on which is best, but I have a Mityvac and it works well. just make sure the oil is hot when you use it.
H
12-15-2009 | #3 |
Another vote for the Mityvac here, I've used it with synthetic fluids for a few years now, with no problems.
12-15-2009 | #4 |
Which model?(Mityvac)
12-15-2009 | #5 |
12-15-2009 | #6 |
I take it back, I thought it was a Mityvac, turns out it's a Motive Power Extractor 1708... same goes it works great.
H
12-15-2009 | #7 |
12-15-2009 | #8 |
I use a BIB pump.. I have the Shurflo brand but a Flojet will work too
http://cgi.ebay.com/SHURFLO-BEVERAGE...item3efaf8b3d0
12-15-2009 | #9 |
I agree with JeffVette, the "vacuum can" type extractor works well for me.
http://www.sjdiscounttools.com/mit7300.html This type uses compressed air to pull a vacuum on the container. A suction hose connected to the top of the container is used to suck up the liquid. When done, you remove a plug and pour the liquid out of the canister. I use it for antifreeze (works well to suck all the water out of the coolant expansion tank so that you can pull the plenum). I have used it for oil, differential oil, etc. I even used it to clean out the pocket below the hood latch. It is a little bit of cumbersome to store. Jim
12-15-2009 | #10 |
Just make sure to clean it after use, will last fine.
There are no limit's mans ingenuity, just as mans ingenuity will never conquer the forces & behavior of this planet...Smokey Y. |
