Old 12-02-2009   #1
xxxscimitarxxx
Default CHASSIS ROT and other stuff
Hi to All
just want to thank all who contributed to my 92 SES light and the hose at the of the plenum which turned out to be the prob.....what would l do without you guys
todays griefs are as follows
1)
as per pic where can l get this cross member section or is it a 'fix it however you can' solution with whatever metal can be welded in
2)
if lm driving normally i dont have any check lights coming up.....but if l give it some right foot the service ABS and service ACR come on simultaneously........when l switch of and start again its a clear light board until l stamp on it again
why is this only associated with heavy driving and whats my prob
3)
the door switch that operates the security 'lock and leave' system doesnt operate either side.....do they work independantly or are they linked....and is it likely to be the solenoid in the door
xxxscimitarxxx is offline   Reply With Quote
Old 12-03-2009   #2
Default Re: CHASSIS ROT and other stuff
The rear cross member does not have a part number listing on my parts CD. It's listed as "no stock".
I would guess that some grinding and welding of plates to rebox it is in order? I would also guess that it is welded at it's ends so that should make removing it to work on it such fun.
I have a 90 so I don't have ASR. I would make the lights come on and then pull the codes so you would have a starting place. Or you could ask the CCM, as it is supposed to store "H" ( History ) codes.
The lock thing I have no idea. Sorry.
Old 12-03-2009   #3
xxxscimitarxxx
Thanks so far ....
I was guessing that cross member didnt have a replacement part even though its quite a formed section with punched holes and shaped ends
so guessing a weld up job will suffice
as for codes l dont have a scanner here.....really do need to buy one....any reccomendations?
as for door locking mech.....my 90 has...but without the shop manual l cant recall the official name for it but its the switch near the manual slider bar lock in the door panel
Old 12-03-2009   #4
What I use in place of my scanner sometimes is the "jumper kit from Gordon Killabrew. The kit has made up jumpers that are inserted into the ALDL and you get a quick code read out. The kit comes with a jumper for the ECM, ABS, CCM for history codes, FX3, etc. Or you could just jumper the needed pins with the paper clip on the ALDL. I keep it in my car. If it throws a code I use the specific jumper to see what's up without having to get down to see what I'm jumping if I used a paper clip.
Okay, yes the power door lock switch in front of the manual slider. The switches are slaved to each other. Check the fuse first? Then the actuator (solenoid) in the door? I don't have my 90 FSM handy, sorry.
Old 12-03-2009   #5
xxxscimitarxxx
Thanks......
re door locks....all my bayonet fuses in the box on the passenger side are good (or is it one of the larger cans)
re codes....I have read about the paperclip method but would like to buy a reccomended cheap scanner that will pop up the codes on a display.....plus the fact that using a clip means lm on my hands and knees twisting like a python to get the damn thing in and groping in the dark flipping my glasses on and off to see what the hell lm doing
but its also odd that both the ASR and ABS service lights come on together when l give it some spirited right foot and not when casually driving....then l turn off....turn on again ....and they are gone till the next time
do any of these check lights cause my secondaries to shut down.....doesnt fel like it does
Old 12-04-2009   #6
Yes, I am not inclined to want to lay down to use the paper clip method. That is why I bought the jumper kit from Gordon. I can check for codes while sitting in the driver's seat with his kit.
http://www.gordonkillebrew.com/
The diagnostics for the door locks is in section 8A, the electrical book.
Old 12-04-2009   #7
Jeffvette
Originally Posted by xxxscimitarxxx View Post
1)
Cut the piece out and weld a new one in.
Check your brake fluid level. Can't remember if the 92 went to a single reservoir, but that will cause your problem under hard acceleration.
"Lock and Leave" do you have an aftermarket alarm system in the car?
Old 12-04-2009   #8
xxxscimitarxxx
re abs check light ...absolutely right....check fluids....duh ...will do in morning
re the lock and leave....no aftermarket fitted
re the cut out and weld in a new one....seems from previous help that there isnt a replacement part so seems l will have to weld in a box of some sort
having a big day tomoz with my son on a few bits and pieces so will advise
Old 12-04-2009   #9
Jeffvette
Can you go into some more detail on this?
Old 12-05-2009   #10
xxxscimitarxxx
my lock and leave switch in front of the manual slide lock bar in the door panel doesnt work on either door.......
l now know they are electrically linked......have been told there is a fuse that works them but cant find a dud.....and dont know at present if the solenoids are to blame.
and was told that sometimes an aftermarket alarm system might disable them.....but no aftermarket alarm is fitted
