Old 12-02-2009   #1
Sgreg
Sgreg's Avatar
Default Fubarred on Fikse wheels/ WTB Fikse ZR-1 fronts
I thought I had an easy fix by applying a spacer to make the early c-4 front FM-5 Fikses work on my 91 Z. WRONG !!!!!!! After spending a wad for a custom spacer, guess what ? It looks like s--- ! Sticks way out beyond the fender line and is probably dangerous and looks like crap. So much for eyeballing. There are two cures as I see it. Try to find two correct ZR-1 offset FM-5 fronts to buy or trade for or find someone who can duplicate the barrels on what I have to the correct offset (very expensive). Boy this is really easy. Anybody got two Fikse 89-96 C-4 or ZR-1 spec FM-5 fronts for sale or ???
1991 ZR-1, Black, Black, # 541
Sgreg is offline   Reply With Quote
Old 12-02-2009   #2
Default Re: Fubarred on Fikse wheels/ WTB Fikse ZR-1 fronts
Originally Posted by Sgreg View Post
I thought I had an easy fix by applying a spacer to make the early c-4 front FM-5 Fikses work on my 91 Z. WRONG !!!!!!! After spending a wad for a custom spacer, guess what ? It looks like s--- ! Sticks way out beyond the fender line and is probably dangerous and looks like crap. So much for eyeballing. There are two cures as I see it. Try to find two correct ZR-1 offset FM-5 fronts to buy or trade for or find someone who can duplicate the barrels on what I have to the correct offset (very expensive). Boy this is really easy. Anybody got two Fikse ZR-1 spec FM-5 fronts for sale or ???
the fronts only need to be 89-96 specific, not ZR-1 only.. that might help on your search
they too far in without spacers or??
Old 12-02-2009   #3
It Sticks before the spacer or after the spacer. Im assuming before? If after why cant the spacer be milled down? Got a pic? GC
Old 12-02-2009   #4
Sgreg
Sgreg's Avatar
Just a poor fit really. Too much rim outside the fender line. Far deeper dish than stock.
Old 12-02-2009   #5
Damn that sucks!!!
Old 12-02-2009   #6
Jeffvette
Trying to clear the brembo calipers?
Old 12-02-2009   #7
Sgreg
Sgreg's Avatar
That too, but even with stock calipers, there would be a problem with fit. My fault entirely, but with Fikse out of business, I can't change the barrels. So I just hope I can find two 89-96 fronts.
Old 12-02-2009   #8
Jeffvette
Check with 1990 415, he might have a set of spares.
Problem you are finding is that three piece wheels can be configured differently. You have the depth of two different barrel pieces and the hub of the centerpiece.
Old 12-02-2009   #9
Sgreg
Sgreg's Avatar
Yep, that's about it. I fired a PM to 1990 415 and am keeping my fingers crossed.
Old 12-02-2009   #10
1990 415
I might just make you happy this Christmas.
1990 415 is offline   Reply With Quote
