Old 11-10-2009   #1
karlaw
Default 1990 engine/ rebuild parts needed
need some rings, bearings, gasket kits, etc to rebuild my 1990 ZR-1. It lost oil pressure on start up, and started knocking. Also would consider complete drop in engine.
rd.adam@shaw.ca
karlaw@telusplanet.net
karlaw is offline   Reply With Quote
Old 11-10-2009   #2
limey
Default Re: 1990 engine/ rebuild parts needed
Everything you need in one kit.
http://www.whiteracingproducts.com/i...roducts_id=985
If though you prefer a bolt in motor, i think Phrogs has a used bottom end for sale.
limey is offline   Reply With Quote
Old 11-11-2009   #3
karlaw
I checked their site, seems like very high price for a rebuild kit. Is there any other sources out there ?
Old 11-12-2009   #4
Check www.jerrysgaskets.com for all LT5 gaskets & seals.
Old 11-12-2009   #5
Kb7tif
http://www.zr1specialist.com/HAT%20W...For%20Sale.htm
Heres an option
1995 Convertible Supercharged Auto
1974 454 550hp (avatar car) On the blocks- -Scharger install !
1992-Zr-1 Sold.
Watson Headers
Ported Plenum, Housings
Random tech cats
Fidanza Flywheel
Chipped, Relocated Mat
Woods 165 stat
Borlas, Straights
1996 Lt4 Sold
1994 Lt1 Sold
2004 Z06 Sold
AKA** Illenema
Kb7tif is offline   Reply With Quote
Old 11-12-2009   #6
Pete
Pete's Avatar
LMFAO
Still LMFAO
www.LT5parts.com
I fell off my sit from LMFAO
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 11-12-2009   #7
limey
It certainly is a high price, esp. when considering a 350 SBC would cost you maybe $500.00 or so.
Look up GM prices from when items were available and it's even more scary.
Piston rings $202.80 each piston x 8 = $1622.40
Main bearings set was $278.61
Not to mention all the gaskets and seals and such.
Call Haibeck, he gets bearings re-coated & can probably re-coat yours for a couple hundered dollars. Jerry has a full gasket set, runs about $800.00 i think. You'll also need the cam cover to cylinder head plugs, Jeff Flint has these @ about $22.00 each, youll need 8 of them, Piston rings are available from LT5-Parts.com for about $700.00. I think pete can do the rebuild for you at a rather low cost, he does lots of porting work and has a very fast car, so maybe he can get you a hook up and get you some more power while you're in there. Don't forget Phrogs, he has a short block he's wanting to sell, i think its from a 1990 as well. Parts are out there if you want to piece together and save some $$$$, just need to shop around.
Old 11-12-2009   #8
Hammer
Hammer's Avatar
Talking Re: 1990 engine/ rebuild parts needed
Probably not for complete set of rebuild parts all in one place.
Old 11-13-2009   #9
cvette
Wow!!!!!!!!!!!
cvette is offline   Reply With Quote
