Old 11-08-2009   #1
Default Dom...Byron results???
So...Do tell how Byron datalogging went yesterday! (I couldn't get away in time to make the trip [sigh]).
P.
Old 11-08-2009   #2
Default Re: Dom...Byron results???
Yeah?? how did it go?
You ready to port the heads now for more power???
paul,
good seeing you for lunch on Friday..
Old 11-09-2009   #3
paul,
Jeff,
I think there's more "bang for the buck" with new tires and a new driver.
The trap speeds are indicative of a low 12 car right now without heads but a 2.3 60' isn't going to get there. Not to mention 2nd gear.
Old 11-09-2009   #4
P.
Paul,
It was a beautiful day with few drivers out there. I'd already done 5-6 runs by noon. But the launch was more like "budda". Lousy 60". My best time came with tires at 29.5psi, 2.1 60", a 12.9 x 117.26mph. I will say there was a headwind today at Byron. The track faces south and that's where the wind was coming from which provided the 72d temps. DA corrected times were in the 12.6 @ 119+mph.
I was able to datalog one run. Looks like there's run to lean things out a bit. Little to no knock retard.
Old 11-09-2009   #5
Paul,
Ah, sorry 'bout the traction? As for leaning, what ratio have you found seems to work best for your LT5? Would it be around 13.0-13.5 (as some have suggested)? (Assuming you do run you wide-band sensor on the track, yes?)
P.
Old 11-09-2009   #6
jonszr1
jonszr1's Avatar
when corey tuned my car we found that we made the most power @12.8. and 26.5 total timing. but we tuned my car on 91 oct as that is all we have out my way
Old 11-09-2009   #7
P.
Paul,
I think the idea is to be a bit rich at torque peak since this is the most likely area where you'll experience knock retard, then lean it out as you head to top end. I would not go any leaner than 13.1 for the top.
Yes I did datalog a run this Saturday, and the AFR looked a bit fat. I had little to no knock retard so I could lean it out a bit and/or try some additional timing.
Old 11-09-2009   #8
The 91 octane would cause the lower advance. Having seen other Corey cals, he's more aggressive than that
