![]() Join Date: May 2008
I would like to buy two (2) usable and complete piston assemblies - piston, piston pin, rings (all 3 of them), and connecting rod, from a 93-95 LT5 engine. If you only have part of what I need, let me know.
Thanks,
Clint aka billybaloneey '94 - C4 ZR-1 #445 - Black/Black '05 - C6 silver/black 6sp '85 - C4 white/graphite (almost done) automatic '78 - C3 silver/black (a work in progress) automatic |
![]() Join Date: Jul 2004
I have these from a 90-91 motor I don't know if they are different or not I thought the pistons were the same??
If they are the same and you need these let me know $100 each comes with piston rod and the rings still on them. jp
#3 | |
Also on the "Members Only" portion of the ZR1netregistry...the section about "LT5 Engine Specs" it does mention differences....the rods were lighten, pistons were strengthened, differences in all 3 rings, it even says the piston pin had a design revision. Physical dimensions are the same. So I now have a near complete set of LT5 piston assemblies...but, according to Marc...they are just a little different in weight for my '94 rebuild/project engine. You were actually one of the few I thought might respond with what I needed...but apparently the earlies are not 100% interchangeable with the laters. Thanks,
Well **** I guess they are different
