12-20-2012 | #1 |
Clutch Fork Failure Analysis Prediction?
Here are some additional pictures of the broken clutch fork from a 1994 ZR-1 with greater than 130,000 miles.
The goal of our analysis was to determine if the failure could have been predicted by visual inspection prior to the failure. The fork failure occurred during a routine shift from second to first gear while Yun was entering the parking space in the parking garage at his condo. There were no prior indications of clutch operational degradation. Here are some close up pictures of the fracture: It looks like the fork suffered fatigue failure under tensile stress during clutch opeartion. There is no indication of deformation (twisting or bending) occurring prior to the failure. There is no indication of mechanical damage (strikes, marks, or scrapes) to the fork prior to the failure. The failure crack probably started in the edges of the rivit hole and spread outward to the edges of the fork. I suggest visual inspection of any clutch fork that is to be reinstalled. Examine the area around the rivit, looking for cracks. I would be intersted in any other comments. Jim
12-20-2012 | #2 |
Re: Clutch Fork Failure Analysis Prediction?
Great write up Jim!!! Makes me wish I had taken a better look at my fork before I put my new Bill B. transmission in. Oh well...not to fear...there always the Westminster Loaner Program
12-20-2012 | #3 |
Thanks for the write-up.
I agree with your assessment. Close inspection of rivet hole is about the best one can do. |
12-20-2012 | #4 |
12-20-2012 | #5 |
Jim,
What's your thought of just doing a weld along that bend to add some cross section as a preventative measure?
12-20-2012 | #6 |
You know what they say about big feet?......
Big broken clutch fork!!!!!!!!!
12-20-2012 | #7 | |
For it to be worthwhile reinforcing has to be on the open end on the break and around the begining of the crack - around the rivet. I don't know such small weld is doable. Maybe a plate with a hole for the rivet and weld over the hole/rivet and around the edge of the plate. A few holes on the plate filled with weld will be worthwhile. Again this is such a small area to work with... Not to mention clearance concern after adding the plate. |
12-20-2012 | #8 | |
Just remind me to NOT let you step on my foot at the Gathering in May. lol On a serious note, I'm glad you got it fixed. The fracture is an anomoly, IMO. I don't think I'd ever bother reinforcing one prior to installation. Maybe if you drag race or do brutal shifting?
12-20-2012 | #9 | |
All of the suggestions are good, but the fork is not a very expensive piece. I was hoping to get a quick visual Go-No-Go inspection that could be used to decide if a replacement fork is prudent when the clutch is apart for some other reason. Jim |
12-20-2012 | #10 |
Hello Jim,
Could heat have any effect on the part to cause it to break ? Nelson007 |
