View Poll Results: Which coil packs do you have? | |||
AC Delco |
53 | 71.62% |
Accel |
4 | 5.41% |
MSD |
17 | 22.97% |
Voters: 74. You may not vote on this poll |
#61 |
![]() Join Date: Jan 2004
I know this is a very old thread, but so far I haven't seen any evidence of
1. fancy spark plugs 2. super conductor wires 3. coils that are "better" than factory the gm stuff works and will support reliably over 700 hp so why mess with success. Over the years all the fancy msd and deamon coils seems to suffer early failure and until I see a baseline dyno, and then another one after the swap make more power, I think the stockers might be the best. But maybe the old coils are better than the crap AC delco slings out now. I ran the fancy magnecore wires, big chunks of the silicone just fell out of the wire like it had been cut out. The factory stuff is engineered better, and seems to light the fire just fine at even higher compression ratios. I've tried the fancy plugs, wires, coils, now I listen to Pete because he's faster than I am with a stock block Dyno is the truth teller and cuts through the BS about what works and was doesn't MPH at the track is a good tell also Phil, I'm glad you are running the MSD stuff, I hope it holds up. I heard bad things about the Accel, deamons, and the MSD over the years. QA on MSD and parts in general is in the tank with out of box failures being more common In the old days of "waste spark" the coils would corrode and go south after 20-30 k miles You would notice misfires, and high boost power drop off. With high cyl pressure of the Lt5, you would think the stockers wouldn't be that great. I have 106k miles on the old 95 coil packs and I wonder if I should change them out with "new delco NOS" which seems to stand for :"not optimum sh!t" in recent years after the many folks went to cheap manufacture at the price of quality. Me thinks the old stuff was better. |
#62 |
![]() Join Date: Nov 2007
AC Delco
#63 | |
![]() Join Date: Mar 2018
I have nothing against running the factory stuff, however you're the first person I've seen who said they had problems with magnecor wires. They do come with a lifetime defect warranty. I've had a set on my RX-7 for many years with zero issues. I didn't want to run a set of "new old stock" so I decided to run a new set of magnecor wires on my Z. We'll see how the ones I have will hold up. Last edited by Great White; 03-14-2022 at 01:17 PM. |
#64 |
wow, didn't know the magnecore had that guarantee. I think I still have them and might see if they stand up and replace the one wire that shat the bed
no critters, I was still driving the car and it ran great but made me nervous with a chunk of the wire missing. |
#65 |
![]() Join Date: Jan 2013
BWD coils, made in the USA.
#66 | |
![]() Join Date: Jun 2013
#67 |
![]() Join Date: Aug 2012
I have a misfire and emailed Marc and he said coils. When I asked which brand he said, "We use AutoZone Duralast C849. They are made by Wells and are of excellent quality".
That works for me.
#68 | |
![]() Join Date: Jul 2007
Awesome I thought I ordered AC Delco yesterday but must not have hit complete order, so thanks to Marc for this tip, I ordered them and saved some $$ at the same time Make sure you order qty 2 of C849-2 (it is a 2 coil kit) that is the best way to buy them, they have a 3 coil kit and then you need one more which ends up costing more
#69 |
Yes, the two coil kit is a great deal, much more cost effective compared to buying the single coil.
#70 |
![]() Join Date: Dec 2019
ac delco is overated over priced parts these days
95 admiral blue z(sold)/ / 93 ruby z(sold) 91 steel blue z/95 aqua z haibeck 510, 91 callaway 415 areobody #5 |
