Old 10-22-2011   #41
Default Re: Dyno Day
Originally Posted by Pete View Post
Then you'll be happy with 432
Yeah your right your an old stuburn WOP
Pete(
Well at least not as old as Frank.
Old 10-22-2011   #42
Well, it will be interesting to see what you get with the same system that I have. I guess it will come down to a test of the heads and your cams.
But, one of my "winter projects" will be to change the muffs to the 3" Dynas, and coupled with the new radius in my IHs, maybe I'll see 440 ish...not to put the screws to an old WOP friend of mine...at least not toooooo bad!
P.
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 10-22-2011   #43
Paul,
You'll need to do that on the same dyno in order to compare apples to apples.
Old 10-23-2011   #44
Sure........leave us white hair's out of this !
Frank Urbo.
NCM Lifetime member # 982
Registry Founding # 237
Old 10-23-2011   #45
Got the SW Xpipe. I thought this was interesting and not expecting to see this:
Is this a newer version? Trying to deal w resonance?? How does it affect flow?
This "baffling" is in the aft part of the Xpipe. Its in the section behind the X where they are merged.
Old 10-23-2011   #46
Pete
Pete's Avatar
WTF is that?
Send it back,looks like sh!t.
All the ones i've seen are straight 3"
Can you post a picture of the outside body.
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 10-24-2011   #47
sammy
wow thats different . looks like the noise reduction cones that they put in header collectors to quiet open headers at the track . also kinda looks like someone welded a cheese grater in your pipes jk . sure could mess with your exhaust flow
Old 10-24-2011   #48
Looks like an X pipe with a bad case of hemeroids!!
I don't like it - at least not until there is some "with and without" data to at least show it is benign (which I doubt!). I guess we'd like to hear what SW has to say about it, as I'm sure you're going to give 'em a call.
P.
90 #1202
Sans secondaries
Old 10-24-2011   #49
P.
Paul,
Yeah I'll be calling them later today. I'll keep you posted on what they say. This is definitely not what they have pictured on their website. This isn't cheese grater stuff. It's bumps in a spiral pattern located in about a 10-12" section of the Xpipe behind the merge point and prior to the exit opening.
Old 10-24-2011   #50
Bumps reduce velocity loss against the wall of the pipe?
