-   -   Dyno Day (http://zr1.net/forum/showthread.php?t=15854)
XfireZ51 10-15-2011 04:07 PM
Dyno Day
Finally got opportunity to put car on dyno yesterday at Speed Inc.
It was somewhat disappointing for a couple of reasons. In its previous configuration on the same dyno, the motor pulled ~399rwhp with a peak of 6800rpm. With several successive pulls, we didn't get more than 414rwhp this time. The previous config. was ported top end, headers, full exhaust, and my tuning. Now the motor sports GVD heads, Pete's Intake regrinds, again full exhaust and previous top end porting.
As a caveat, don't take these numbers as etched in stone at this point. It took 9 pulls and 2 hours to get the AFR numbers near where they should be. Quite a bit of additional fuel was needed for this configuration. Myself and the dyno opertor had agreed that if we saw an AFR > 13.2, he would shut it down. So we did this and got to 7000rpm+ in stages. The AFR curve I now have is much better than what I came in with. In some cases, AFR was climbing towards 14:1. One GOOD reason not to run the car last Sunday before getting it on th dyno. The curve still needs a bit of tweaking but it needs to be right before I would play with timing. I did do some datalogging just to check for Spark Counts. With the timing tables I have there now, I only had 1 Spark Count near 6K and then very briefly. Timing was retarded by 1d for 1-2 frames. Not enough to be concerned.
Consulting w Pete, our thoughts are that:
1. The air bridge is likely collapsing. It continues to squirm off the air cleaner assembly regardless of how much I tighten the worm screw. Pete says that is a sign of the snorkel being pulled away by the suction of the motor. Although I have one of Marc H's "hoops" inside, the air bridge may be collapsing particularly at the housing end.
2. I may have discovered the limits of the MagnaFlow resonator. Up to this point, it didn't appear to be a bottleneck, but with the increased flow (the addtional fuel needed really suggests that) it may not be able to move the exhaust efficiently at this level of power.
Bottom line is I will try to get back to the dyno before the snow flies but first addressing the airbridge collapse and resonator restriction issue.
In the meantime, here's a vid of the car on the dyno yesterday.
http://vid187.photobucket.com/albums...h_PICT0003.jpg
I'll post dyno sheet one I get data file of it from Speed Inc.
BTW any suggestions on the exhaust issue are welcome. Right now I am trending towards removing the resonator and Xpipe combo and replacing with SW Xpipe and 2-3" straight pipes in its place. I'll worry about the drone later I guess.
GOLDCYLON 10-15-2011 04:46 PM
Re: Dyno Day
Dom maybe a solid Coplan insert for the accordian? Vice the Haibeck hoops or install 2 more hoops toal of 4. 2 Each opening and 2 in the middle ?
I can loan you a Corsa spare resonator I have in the attic to test out.
BTW always love that sound
Paul Workman 10-15-2011 05:10 PM
Re: Dyno Day
At different times I've run across discussions regarding the intake to the plenum as another consideration. To that end, the surface of that "accordion" pipe between the air horn and the filter housing...always troubled me. Everywhere else, runners sweep this way and that, turns follow careful radii, and attention is paid to keep the surfaces relatively smooth. And, then there is that convoluted, accordion-like snorkel...:icon_scra
I wish I had "before and after" data; "before" being the stock tube (or maybe allowing wire hoops in the convolutions to prevent the tube from collapsing) and after with a sleeve inserted in the tube, not only to keep it from collapsing (what they are usually used for), but to see if straightening out the flow has some tangible value.
In talking with Pete, he removed his snorkel for racing one time, and is convinced it slowed him down. Reinstalling the tubing picked the performance back up (he says-and he races a lot). Just wondering what the rest of the Brotherhood's experiences/comments might be..
P.
John Boothby 10-15-2011 05:28 PM
Re: Dyno Day
I run a Samco intake duct. Smooth and won't collapse.
GOLDCYLON 10-15-2011 05:55 PM
Re: Dyno Day
P.
Why I use the Coplan insert... Smoother no collapsable airflow is key
FU 10-15-2011 07:31 PM
Re: Dyno Day
Smooth Samco here. If anyone would like to borrow it for a back to back runs on the dyno or at the strip ? Just lemme know.
XfireZ51 10-15-2011 09:18 PM
Re: Dyno Day
I had some aluminum sheet so I built an insert today. Quite a bit stiffer!
GOLDCYLON 10-15-2011 09:29 PM
Re: Dyno Day
Cool do you want to borrow my Corsa resonator? Daryll
XfireZ51 10-15-2011 10:07 PM
Re: Dyno Day
GC,
Think I'm going w a SW X and some straight pipes. Another alternative could be using LT4 resonator.
GOLDCYLON 10-15-2011 10:15 PM
Re: Dyno Day
Ok offer still holds. Haibeck used the Corsa system in his slides. Just saying
