Old 04-15-2014   #31
Default Re: Dulso remover
old thread.. but working on a different bezel.. I don't like the new bezel anymore, especially with the tablet..
I want to keep the 94 drivers console side but the 90-93 'wall'
here is the part still in process
Dulso is tough to remove on this one
Once this one is done, I will start on a center console piece as well
Does this have anything to do with you wanting a C7?
Old 04-15-2014   #32
Schrade
My '94 must have had some aftermarket stuff on it, because once you 'broke' a spot, it would roll up under HARD finger / thumb pressure...
Old 04-15-2014   #33
No, not really.. still want a C7 though
Yeah, some parts are that way others are not
Old 04-16-2014   #34
I realized my part is from Corvette America.. I got all of the dulso off.. working on sanding it now. there are flaws underneath that rubberized coating..
got a bit more done on the bezel.. I need to cut the radio opening a bit on the bottom for my tablet.
Then drill holes for Power key and the Volume and balance controls..
Here it is waiting for my acetone/abs sludge to completely dry and harden
Old 07-23-2014   #35
Check out those bezels now:
Radio:
Console:
Stock OEM bezel is the top one for comparison
Old 07-23-2014   #36
Pretty Slick -=JEFF=- hows my down in one plug and play adapter coming ?
Old 07-23-2014   #37
On my list..
I have not sourced the mate connector that is on the driver side switch assembly.. that is needed for the 'plug and play' kit.
I have the express down module (2 actually) but I am debating installing the complete window automation module I have for express up and down plus capability from the remote..
if I decide not to do that I will do express down on both windows only using GM modules
Old 07-23-2014   #38
Oh..
Radio bezel compare:
