#21 | |
#22 |
![]() Join Date: Nov 2007
PM Sent
#23 | |
![]() ![]() Join Date: Jul 2005
Having had an engine fire (LT1 when the forged crank broke), as well as Brett (L98 when a fuel line O-ring failed), you’ll find that the hardest part is treating all the corrosion from the extinguishant, vs. replacing damaged parts. Nasty stuff, and it gets everywhere. Inside the car as well as all over the drivetrain. Despite quickly being able to pressure wash everything, I still had massive corrosion which resulted in taking my car down to the chassis- Everything had to come out/come off. Clutch looked like it was 30 years old. Rust on everything. Lots of cleaning, sanding, priming, painting.... most every nut, bold, and fitting replaced. Until you really pressure wash out the engine bay, I’d be even be weary of putting it in my garage - again, incredibly nasty stuff. IMG_5556.JPGIMG_6538.JPG Sent from my iPhone using ZR-1 Net Registry
Mark Horner President, ZR-1 Net Registry 91 ZR-1 #2016 95 ZR-1 #21 DRM-600, LPE 385 Last edited by Vette Guy; 04-28-2020 at 11:58 PM. |
#24 |
![]() Join Date: Aug 2006
Hey Mark!
Hope you are making the most out of this crazy time. I keep a Halguard extinguisher and Halguard claims clean agent. Is this the same kind of agent as you had experienced? https://www.h3rperformance.com/p4234-hg100c |
#25 |
I did not have a Halguard, but the car was equipped with a Lifeline FIA certified 4 liter, 8 nozzle aqueous film forming foam system, and I carry an additional 4lb class B/C extinguisher. When I egressed the car, I didn’t know the extent of the fire and was reluctant to pull the AFFF as it would spray not only the engine, but fill the interior as well. I grabbed the hand-held and went to address the fire, knowing I can grab the second activation pull located outside the car if needed... (it’s also $500 if I pull it). I quickly extinguished the engine fire, but couldn’t get the fire out in the tunnel, which continued to flare up. The AFFF system would not have reached it either. I went through my 4lb handheld, as well as a larger extinguisher provided by a course worker to keep it at bay until the fire trucks arrived. Brett’s fire was before this, and he warned me.... but it was worst than I’d ever imagined it could be. The DEI heat shield did a great job of preventing the fiberglass from catching fire, but the rubber bellows of the ZF-6 kept the fire going until the fire trucks finished it off. They went through quite a few bottles before the big hose was finally used.
IMG_5440.JPGIMG_5441.JPG Video of the event: https://youtu.be/gw60JxU-zYQ So, now I carry an Element fire extinguisher, which is about the size of a flair, and does not make a mess. Video of Element on Jay Leno’s Garage: https://youtu.be/oBjXecsF860 Please note, it took me way too much time to realize there was fire vs. coolant, etc., and I’ve since taken the time to practice much quicker egress! Sent from my iPhone using ZR-1 Net Registry
Mark Horner President, ZR-1 Net Registry 91 ZR-1 #2016 95 ZR-1 #21 DRM-600, LPE 385 Last edited by Vette Guy; 04-28-2020 at 11:56 PM. |
#26 | |
Now that my Z is 26 years old, I started carrying a bottle of extinguisher just in case. But, not sure if 2.5 lbs bottle can do the job. |
#27 | |
![]() Join Date: Dec 2015
Interesting and good information. I am not seeing any sign of foam or extinguishant just yet. Makes me wonder what the fire was put out with.
1991 ZR-1 #1900 Black/Black ![]() |
#28 |
If you don't already see corrosion, you're probably in good shape! Whew!
Mark Horner President, ZR-1 Net Registry 91 ZR-1 #2016 95 ZR-1 #21 DRM-600, LPE 385 |
#29 |
![]() Join Date: Aug 2012
That Element fire extinguisher is very interesting and will fit right into the center console. Appreciate the heads up on this product.
#30 |
There’s your problem right there. Air duct is collapsing at WOT. Haha
[/ATTACH]
