Old 04-28-2020   #1
Vette Guy
Vette Guy's Avatar
Default Re: Engine Fire??
Originally Posted by rush91 View Post
And no telling how much water \ foaming agent was doused on there to put it out.
Having had an engine fire (LT1 when the forged crank broke), as well as Brett (L98 when a fuel line O-ring failed), you’ll find that the hardest part is treating all the corrosion from the extinguishant, vs. replacing damaged parts. Nasty stuff, and it gets everywhere. Inside the car as well as all over the drivetrain. Despite quickly being able to pressure wash everything, I still had massive corrosion which resulted in taking my car down to the chassis- Everything had to come out/come off. Clutch looked like it was 30 years old. Rust on everything. Lots of cleaning, sanding, priming, painting.... most every nut, bold, and fitting replaced. Until you really pressure wash out the engine bay, I’d be even be weary of putting it in my garage - again, incredibly nasty stuff.
Mark Horner
President, ZR-1 Net Registry
91 ZR-1 #2016
95 ZR-1 #21 DRM-600, LPE 385
Vette Guy is offline   Reply With Quote
Old 04-28-2020   #2
Hey Mark!
Hope you are making the most out of this crazy time.
I keep a Halguard extinguisher and Halguard claims clean agent. Is this the same kind of agent as you had experienced?
https://www.h3rperformance.com/p4234-hg100c
Old 04-29-2020   #3
owwdee
owwdee's Avatar
Attachment 11890Attachment 11891
Interesting and good information. I am not seeing any sign of foam or extinguishant just yet. Makes me wonder what the fire was put out with.
1991 ZR-1 #1900
Black/Black
owwdee is offline   Reply With Quote
Old 04-29-2020   #4
Vette Guy
Vette Guy's Avatar
If you don't already see corrosion, you're probably in good shape! Whew!
Mark Horner
91 ZR-1 #2016
