#21 | |
![]() Join Date: Dec 2005
I don't want to waste your time with a long phone call until I get deeper into this. I pulled the glove compartment, other than the top of the duct work not much to see Photo 1. Pulled the lower hush panel (Photo 2 and 3) and low and behold looks like someone was there before. Radio receiver and associated wiring is all hanging loose (Photo 4). I see the duct work and the SIR wire but nothing that looks like an actuator or motor. Am I looking in the wrong places or not far enough into this? Thoughts? Thanks, John
1968 convertible Lemans Blue, 1986 coupe Medium Blue NCRS Top Flight (sold), 1990 ZR1 #2529 Red NCRS Regional and National Top Flight (sold), 1990 ZR1 #2124 Charcoal Metallic NCRS Top Flight 2010 & 2018, 2003 Anniversary Red Convertible (sold) Last edited by jrd1990zr1; 08-31-2017 at 05:15 PM. |
#22 |
![]() Join Date: May 2007
John,
In your picture 1, the duct pieces you are looking at supply the air to the small vents that blow on the passengers knees. You have to remove those ducts to get to the top of the main air box that houses the Blend Door. Keep digging and send another picture so I can get oriented with the 1990 setup. Jim |
#23 | |
Replacing the Heater Core and Heater Hose Connection
Clickable links ![]() On Iphone Touchable Links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 09-03-2017 at 11:00 AM. |
#24 | |
![]() Join Date: Jan 2010
Fortunately, no! Never had to go in there. Good luck with yours. Missed ya @ Carlisle, nice time was had by all! D |
#25 |
I just remembered something about the HVAC system that affected my trouble shooting. The HVAC programmer needs to be powered off (Battery disconnected) after any changes you make to the system.
You may want to try disconnecting the battery now and see if the system returns to normal operation. Jim |
#26 | |
Had to but it back together so I could get the mandatory annual NYS inspection. While driving there it set a Code 09 on the AC, low freon, so looks like I have a slow leak. Last charged it 2 years ago. No heat and no A/C. Looks like I've got a couple winter projects. John ![]()
1968 convertible Lemans Blue, 1986 coupe Medium Blue NCRS Top Flight (sold), 1990 ZR1 #2529 Red NCRS Regional and National Top Flight (sold), 1990 ZR1 #2124 Charcoal Metallic NCRS Top Flight 2010 & 2018, 2003 Anniversary Red Convertible (sold) |
#27 | |
If you remove the heater box from the inside can you access the blend door actuator to replace it? Did you have to remove the fuse panel to access the heater core box? Thanks for the information. John
#28 |
So I am back to trying to find the actuator for the blend door. I've removed the dash pad, lower hush panel, console trim panels, etc. Bought a fiber optic scope and still can not find the actuator.
Per the service manual, it looks like I need to remove the distribution duct which involves removing the fuse panel and instrument panel. Before I go forward I have to ask, does anyone have a better way to get to the blend door actuator rather than removing the entire instrument panel? Below are photos of where I am now. I am really stuck, so please let me know how you have changed out the blend door actuator on a 1990. Last question is the lower blend door pivot where the read arrow is pointing in the third picture? Thanks
#29 | |
Clickable links ![]() On Iphone Touchable Links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS |
#30 |
