#21 |
It was 45-50 this past weekend. Was in garage putting car up on jackstands getting ready to install DRM brackets and Michelin 345s on rear wheels.
Also pulling front fascia off to get stripped and repainted. Motor started right up, warmed up and idled down to 875-925 nicely. I did notice a very small coolant leak coming from lower rad hose to thermo housing. Not sure if it was part of cold weather startup or if hose clamp needs tightening. Supposed warmer weather this weekend, so I'll be checking it out. |
#22 |
![]() Join Date: Jul 2015
Had mine out on Sunday afternoon. Had been mostly dry for a few days and 64 degrees here in Indianapolis. The wife insisted we take a quick drive and who am I to complain! Also gave me an opportunity to look at a few areas of paint I need to touch up and polish in good daylight, as well as get a good look at the Oil Cooler lines that have a bit of a leak.
Other than that, she was very happy to be on the road while NOT in the schmutz that was our trip cross country. ![]()
--Marc 1990 ZR-1 #2530 Gone but not forgotten: 1988 Z52 4+3 1992 LT1 6 speed |
#23 |
![]() Join Date: Nov 2007
![]() If you hadn't heard, the few days immediately preceding the C4 gathering at Bowling Green will see the Mountain Run #4 (MR4) take place - spending 3 days exploring some of the best known "twisties" anywhere. There you'll get to experience some of what the Z was designed to do with several of or Z brothers AND some GS drivers as well! Keep an eye on this site for "MR4" announcements, as planning is in the works as I type this! |
#24 |
Ok I had to laugh Dom. This just happened to me. I tightened all the SAMCO stainless clamps and they ALL appeared loose. Mine was dripping from the same dam spot. The coolant bleed line was running from where the hose connected to the middle of the lower TH connector.... then onto the garage floor.
#25 | |
Never understood the way those Heater Hose Connections Functioned without leaking ![]() ![]() ![]()
Clickable links ![]() On Iphone Touchable Links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS |
#26 |
![]() Join Date: Apr 2004
Ok it was almost 65 here today so I got both out and let them run.
#27 |
Will be Mid 60s more or less for Month Of Feb here in CA.....You Know what I will be doing
![]() Just completed the Top End on this 95 yesterday and fired it up for a test (PERFECT) ![]() ![]() ![]() ![]() TB Coolant IS Blocked even thought it appears NOT ![]()
Clickable links ![]() On Iphone Touchable Links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 02-02-2016 at 08:40 PM. |
#28 | |
![]() Join Date: Apr 2015
Thanks, Craig.
Looks like a nice versatile cruiser/cross bike in your pics … and even the Corvette name on it. Quote:
'94 ZR1 LT5 - Dark Red Metallic '79 L82 4-speeds of fun '96 LT1 Borla, H-pipe, TB, CAI (Sold) "An adventure is only an inconvenience rightly considered. An inconvenience is only an adventure wrongly considered." -- G.K. Chesterton |
#29 |
![]() Join Date: Jan 2010
2282's tucked in at least until Tax Day...
#30 |
![]() Join Date: Jul 2013
Today, yesterday and most days before that! Just crossed 60k.
