Old 02-02-2016   #21
Default Re: Did you fire up your ZR-1 today?
It was 45-50 this past weekend. Was in garage putting car up on jackstands getting ready to install DRM brackets and Michelin 345s on rear wheels.
Also pulling front fascia off to get stripped and repainted.
Motor started right up, warmed up and idled down to 875-925 nicely.
I did notice a very small coolant leak coming from lower rad hose to thermo housing. Not sure if it was part of cold weather startup or if hose clamp needs tightening. Supposed warmer weather this weekend, so I'll be checking it out.
Old 02-02-2016   #22
BlackSheepz
Had mine out on Sunday afternoon. Had been mostly dry for a few days and 64 degrees here in Indianapolis. The wife insisted we take a quick drive and who am I to complain! Also gave me an opportunity to look at a few areas of paint I need to touch up and polish in good daylight, as well as get a good look at the Oil Cooler lines that have a bit of a leak.
Other than that, she was very happy to be on the road while NOT in the schmutz that was our trip cross country.
--Marc
1990 ZR-1 #2530
Gone but not forgotten:
1988 Z52 4+3
1992 LT1 6 speed
BlackSheepz is offline   Reply With Quote
Old 02-02-2016   #23
Well, everyone knows the RED ones are the fastest!!
If you hadn't heard, the few days immediately preceding the C4 gathering at Bowling Green will see the Mountain Run #4 (MR4) take place - spending 3 days exploring some of the best known "twisties" anywhere. There you'll get to experience some of what the Z was designed to do with several of or Z brothers AND some GS drivers as well!
Keep an eye on this site for "MR4" announcements, as planning is in the works as I type this!
Old 02-02-2016   #24
Ok I had to laugh Dom. This just happened to me. I tightened all the SAMCO stainless clamps and they ALL appeared loose. Mine was dripping from the same dam spot. The coolant bleed line was running from where the hose connected to the middle of the lower TH connector.... then onto the garage floor.
Old 02-02-2016   #25
As an aside......
Never understood the way those Heater Hose Connections Functioned without leaking
Old 02-02-2016   #26
Ok it was almost 65 here today so I got both out and let them run.
Steve
1990 Steel Blue/Black #2355
1990 Red/Red #1473
1991 Quasar /Black #118 Sold
1993 Yellow/White #179 Sold
Old 02-02-2016   #27
Will be Mid 60s more or less for Month Of Feb here in CA.....You Know what I will be doing
Just completed the Top End on this 95 yesterday and fired it up for a test (PERFECT)
TB Coolant IS Blocked even thought it appears NOT
Old 02-02-2016   #28
G-Sting
G-Sting's Avatar
Nice bike. Not a mountain bike, but got my eye on this one.
Thanks, Craig.
Looks like a nice versatile cruiser/cross bike in your pics … and even the Corvette name on it.
You have a gift, Dynomite.
'94 ZR1 LT5 - Dark Red Metallic
'79 L82 4-speeds of fun
'96 LT1 Borla, H-pipe, TB, CAI (Sold)
"An adventure is only an inconvenience rightly considered. An inconvenience is only an adventure wrongly considered." -- G.K. Chesterton
G-Sting is offline   Reply With Quote
Old 02-02-2016   #29
Mystic ZR-1
Mystic ZR-1's Avatar
2282's tucked in at least until Tax Day...
Old 02-04-2016   #30
8cam
Today, yesterday and most days before that! Just crossed 60k.
