10-08-2015 | #21 |
Re: Clutch Out, Which Should I Buy?
Steve, if you are talking about the shifter the answer is yes, I have one of each installed in each Callaway.
As for the Ram dual disk,I do not as of yet. All of my past race cars had Powerglide transmissions and currently none of my Corvettes need a clutch so I have not updated to the RAM. Black LPE will be the first to get one. I have talked with several of our members with the big HP big cube cars and they sware by them. My thought is if you are going to resurface your DMF, recondition your slave cylinder, replace your clutch, throwout bearing and clutch fork. You are at somewhere between $800-$1000. Why not upgrade for an additional $300. Have you had a bad experience with the DD?
Robert J. DeMarco [SIGPIC][/SIGPIC] [COLOR=blue]G[/COLOR][COLOR=red]rand[/COLOR] [COLOR=blue]S[/COLOR][COLOR=red]port[/COLOR] Registry Lifetime Member NCM Lifetime Member #2655 Pacecar Registry Member [COLOR=red]ZOOM Charter Member - ZR-1 Owners of Michigan[/COLOR] [COLOR=plum][I]ZR-1[/I] Registry member since 2012 [/COLOR] [COLOR=black]1990 LPE "368" Aerobody ZR-1, Last ZR-1 built by John[/COLOR] 1991 Callaway Aerobody ZR-1, DRM 500 1991 Shinoda Aerobody Spyder, 1998 Pace Car Last edited by cvette98pacecar; 10-08-2015 at 05:37 PM. |
10-08-2015 | #22 |
Robert, I did a Ram single disc, pressure plate, light weight flywheel, and hydraulic throw out recently. I'm not ready to post about it yet.
10-08-2015 | #23 |
Please let me know how you like it, as well the rattle compared to the fidenza. I am going to do dual disc.
Robert J. DeMarco [SIGPIC][/SIGPIC] [COLOR=blue]G[/COLOR][COLOR=red]rand[/COLOR] [COLOR=blue]S[/COLOR][COLOR=red]port[/COLOR] Registry Lifetime Member NCM Lifetime Member #2655 Pacecar Registry Member [COLOR=red]ZOOM Charter Member - ZR-1 Owners of Michigan[/COLOR] [COLOR=plum][I]ZR-1[/I] Registry member since 2012 [/COLOR] [COLOR=black]1990 LPE "368" Aerobody ZR-1, Last ZR-1 built by John[/COLOR] 1991 Callaway Aerobody ZR-1, DRM 500 1991 Shinoda Aerobody Spyder, 1998 Pace Car |
10-08-2015 | #24 |
I'm holding judgment on how I like it. The rattle is horrible, even part way up the rpm range. I have to keep a lot of torque on the tranny to keep it quite. I can't compare to a Fidanza. I have one, but have not had it installed. The Fidanza is what started the whole clutch install.
10-08-2015 | #25 | |
10-09-2015 | #26 | |
I've had a number of different clutches in my car over the last 20 years and 66K mi. with a fair amount of 1/4 mi. runs. The stock units have never failed. But my car is a stock block 350. The natural impulse is to freshen, or upgrade the clutch if you've got the trans out. But unless the faceplate on the clutch is really beat up, I'd leave the stock pressure plate in. Just pop a fresh disc in there. I'd like to learn more about the dual-disc setups. Are there more advantages to that than it's ability to handle the extra torque of a stroker motor?
"It's about the car, not the people." 1991 ZR-1 White/Black #1236 (Owner since 1994). Stock engine with bolt-ons: Hurst shifter,"Forced Air" intake, Coplon duct, Bee Cool Radiator, Demon coils, Jeal prom, Watson headers, X pipe, 3" B&B's, Rippie flywheel, 4:10 gears, A molds, Toyo Proxes-R888's 12.06@117mph. 1.76 60ft. |
10-09-2015 | #27 |
Here's an interesting thread from the ListServ in 2002.
http://maillist.corvettemuseum.com/c...&F=&S=&P=21713 I have a Fidanza on my ZR and have used one for close to 10 years including on my 84 Xfire w the ZF-6 Trans-plant I did. Although I do have the neutral idle rattle, it only becomes noticeable after the car has been run hard. Part of the reason I use the Camaro disk is because it is a "sprung hub". The hub helps absorbs some of the engine pulsing responsible for the ZF gear rattle. This in combination w the use of the heavier weight Castrol trans fluid does a good job dampening the rattle which occurs only at neutral idle. I have never heard my trans rattling under gas whether just cruising or hard acceleration. Just switched to Amsoil Manual Synchromesh for the trans. In a short drive home from Pete's garage, I honestly didn't notice any difference in shifting. Jury is still out on whether trans rattles more or less than w Castrol.
10-09-2015 | #28 | |
The original clutch is a good clutch. As long as you can maintain it with operative parts, stay with it. That is, unless you have more than roughly 500 RWHP. The real problem is the ZR-1 clutch system is 20 years behind the last model produced. NOS, or NOS quality equivalent, replacement components are getting very scarce and expensive when available.
In summary all of the original ZR-1 clutch components are like a chain... only as strong as the weakest link. In this case weak means availability & cost. For the LT5, the uniqueness & limited production is what will ultimately claim extinction of the ZR-1 original clutch. There is not a large enough market to justify tooling & manufacturing of the flywheel and pressure plate for sure. Even if it did, the quality evidenced thusfar by the reproduction of the release bearing, means it's unlikely to be of serviceable quality. Jim J. told me that ALL Valeo parts today are made in China. Metallurgy is the big concern. In terms of availability, I rank the components as follows. First on the list being the first part to become extinct. 1. Release Bearing: What is available through aftermarket suppliers is junk 2. Pressure Plate: Insofar as ZR-1 original 3000#. Possible to rebuild, not practical due to finger/spring availability & skill to properly recondition. 3. Clutch Fork: Cracked & bent can be repaired, but will eventually wear out. 4. Flywheel: Used will be around, can be reconditioned by experienced shops 5. Fork Ball Stud: 6. Slave Cylinder: 7. Clutch Disc: Common The above reasons are why I decided to become a distributor for RAM clutches, specifically because of the HRB (Hydraulic Release Bearing). The HRB is the method of choice by auto manufacturers today. Using an HRB requires conversion from the stock style "pull=release" to the more conventional "push-release" clutch. Even disregarding availability, the economic viability of maintaining the OEM flywheel & clutch is already an issue. Also gone, unfortunately, is the choice of a dual mass vs single mass flywheel. Increasing the weight of single mass flywheel will lessen the transmission gear rattle caused by engine power pulses, but not as effectively. Increased idle speed and good state of tune will also help. A few words on installation. Conversion of the ZR-1 from "pull-release" to "push-release" is not quite like a normal clutch job with simple "out with the old & in with the new," nor is it a complex job. It just requires common sense attention to details,a basic understanding of how it works, and decent mechanical skills. For our inventory, I am working on refining RAMS conversion kit and the various mix & match possibilities of flywheels & clutches, which is pretty extensive. My goal is to take RAM's excellent component kits, work with RAM to tweak it a little to become a straightforward, step-by-step, plug & play installation, complete with ZR-1 specific, instruction guide & pictures. It's going to take some time, but we are getting there. I know this is an extensive subject & I haven't begun to address it all, but it's a start.
Jerry Downey JERRYS LT5 GASKETS & PARTS http://www.jerrysgaskets.com 1994 ZR-1, Black/Black, Lingenfelter Aerobody, 416cu in, 3.91 gears, coil-over susp, Brembo brakes, etc. 2016 Black-Red, 3LT-Z51 Auto 8-speed. Last edited by A26B; 10-09-2015 at 05:27 PM. |
10-09-2015 | #29 |
Jerry,
I totally agree with your assessment. Luckily I have one fresh set of OEM replacement release bearing, clutch and pressure plate plus a couple more OEM release bearings. Once done with what I have, I know I have no option but to give up OEM set up. Thank you for pioneering Ram dual disc set up. |
10-09-2015 | #30 |
Jerry, I see the RAM clutch listed on your site as a fit for the 89-92 ZR-1s(?). That's good for me, since Ami's and mine are covered. But, curious as to what changed that the clutches wouldn't fit/be appropriate for a 93-95 MY Z?
