Old 06-26-2015   #21
Default Re: DRM Camber Brackets.
Interesting that u say that Bob. Recently had the car up on Al's lift and noted how the rear tires were wearing in the middle of the tread. I have them at 35psi like the fronts, yet the fronts show even wear. I don't track the car except 1 maybe twice a year, so I was surprised that I am nearly down to the wear bars at the back. This may also be a function of having pushed out the rears because of the wider wheels and the offset. More contact patch sounds like the brackets could help.
Seems to me your tire pressure on the rear is a bit high for the tire you are using on the rear.
I cannot think of another reason for wear in the middle of the tread
Old 06-26-2015   #22
At 35 psi the rear tires are over inflated causing the center if the tire to wear faster.
Old 06-26-2015   #23
RussMcB
You can add me to the group order. Thanks for spearheading.
Old 06-26-2015   #24
Originally Posted by cvette98pacecar View Post
... The purple car squats like it is taking a dump.
Robert,
There are times I think of you as the Robert Frost of automotive prose.
Old 06-26-2015   #25
Mystic ZR-1
Mystic ZR-1's Avatar
Robert,
The ZR-1 Net Registry needs a Poet Laureate...
Old 06-26-2015   #26
secondchance
Robert,
I'll take one. Please add me to the list.
Old 06-27-2015   #27
cvette98pacecar
Robert,
I get my inspiration from all of you.
Old 06-28-2015   #28
tf95ZR1
tf95ZR1's Avatar
Hi Robert!
I can always use more parts!
Thanks for setting this up.
Ted
Old 06-29-2015   #29
Vette Guy
Vette Guy's Avatar
Robert,
Please put me down for a set.
Thanks!
Mark Horner
President, ZR-1 Net Registry
91 ZR-1 #2016
95 ZR-1 #21 DRM-600, LPE 385
Vette Guy is online now   Reply With Quote
Old 06-29-2015   #30
5ABI VT
Im in ! I would imagine on a lowered car these can only help?
