Old 07-05-2014   #21
Default Re: Learning to tune....
use the attached ADX
For TunerPro.. Have you?
-Selected
Tools>Preferences
THEN
Data Acq/Emulation
Then
configure plug in component?
That is where the comport setting is..
Also confirm the comport listed there is the SAME as the comport listed in the computer's Device Manager
Old 07-05-2014   #22
Perfect Jeff, you are the man, I owe you one!
Old 07-05-2014   #23
Ok so I will post up some better instructions tomorrow....
To datalog you need
Xtreme ALDL w/cable $80
Tunerpro RT $39
The correct BIN file/The BIN is what turns the Binary date, the 1s and 0s into something we can read
and you are in business. I will show how it works tomorrow.
video of the data in a few...it give the basics. MAP/O2 readings(BLM/INT), spark advance, knock, RPM, MPH, IAC, TPS, etc
Old 07-05-2014   #24
this is tuner pro running off the ALDL
Old 07-05-2014   #25
So that ADX worked? Try it on the 1991 and 1992 let me know if it works, it needs a few tweaks for 91and the others but I want to see if it works as is first
Old 07-05-2014   #26
same exact ADX used in ALDLDroid
Old 07-06-2014   #27
Went out and did a quick data log this morning just to try it.....I failed to get the car up to 7.2K which surprised me.....seeing come knock at 5800..I lifted about 6K
Old 07-06-2014   #28
Data logger only will record rim to about 6500. It is a data stream limitation
Old 07-06-2014   #29
This is where the WB comes in. At 6300rpm you are running Open loop anyway. What you are interested in is kPa, AFR, knock retard(which is likely below 6300rpm if AFR is close), and TPS V and %. So the WB should be good enough for that and give you the rpm reading u need. Run the ALDL AND WB concurrently.
Old 07-06-2014   #30
Hopefully wideband will be here in a few days.....
