Old 05-24-2013   #21
Default Re: Initial thoughts on Pete's Intake/Exhaust cam combo
Here's the compare between Intake/Exhaust cam combination vs. Intake only cams. Each has ported top end and heads.
Top line is current config but prior to tuning.
Here's where I started and ended the tuning session. This was all fuel. Timing really made little to no difference from previous.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 05-24-2013   #22
efnfast
That's the torque curve and it peaks at about 5200rpm.
Got it, sorry, duh. Nice nice numbers. Someday when I grow up.
Old 05-24-2013   #23
Originally Posted by tpepmeie View Post
Actually, I think 244 exhaust with good ports is plenty. I will keep that, add lift. And go bigger on the intake to reduce the time-area ratio. My current setup peaked torque about 600 revs higher than I intended. The ratio needs work I think.
Now back to your thread....
Todd,
BTW, increasing the Injector Offset for the Accels did what was intended. I was actually able to reduce the DC% and VE% for WOT in the table by about 10%. Certainly gives me more headroom w same injectors. I used the voltage table but then realized I could target the additional PW by using the Offset v PW table.
Old 05-24-2013   #24
Awesome #s Dominic! Awesome!
Is that 560 crank?
Old 05-24-2013   #25
Is that 560 crank?
It's 533 or 545 depending on your parasitic loss factor.
Old 05-24-2013   #26
ALZR1
Nice numbers Dominic.
AL.
ALZR1 is offline   Reply With Quote
Old 05-25-2013   #27
Blue Flame Restorations
I can't imagine my Turq car without them.
1990 ZR-1 #444 Convertible
1990 ZR-1 Black #966
1991 ZR-1 Quazar Blue #296
1957 Duntov SS Project
Old 05-25-2013   #28
ALZR1
imagine it send the car back to Pete's for A massage.
AL.
Old 05-25-2013   #29
AL.
Massage to 427ci this Winter and BIGGER cams!!
Old 05-25-2013   #30
ALZR1
now you're talking.
AL.
