View Poll Results: Which Shifter Set-up Do You Have
Stock shifter with stock throw 37 48.68%
Stock shifter modified to short throw 12 15.79%
Short shifter with stock throw (probably zero) 0 0%
Short shifter with short throw 30 39.47%
Multiple Choice Poll. Voters: 76. You may not vote on this poll
Old 11-11-2012   #21
Gunny
Gunny's Avatar
Default Re: What shifter do you have?
Hurst w/stock knob
George Jones
Founding Member #14
www.zrwon.com
Old 11-13-2012   #22
Anniv88
Anniv88's Avatar
Hurst short throw here. Very very little additional effort over stock.
Anniv88 is offline   Reply With Quote
Old 11-19-2012   #23
lakemeadzmonster
Mine is
Stock,but with a recent stock clutch flywheel exct . Complete rebuild after which it shifts like most Chevrolet muscle cars with the longer throws. Not bad if driven based on driving conditions. It would have been a good time to have intoduced a American Muscle car with a short throw Lotus type back in 90.
lakemeadzmonster is offline   Reply With Quote
Old 01-13-2013   #24
sammy
bill boudreaus modified short shifter is the best one out there . i have had both the hurst and bills and his hands down is a little shorter throw and smoother too.jmho
Old 01-14-2013   #25
alwayscode390
Mine is stock, but this is my first experience with the ZF transmission.
My other 6 speed is a T-56 and you go up and right for reverse with no lockout ring to pull up.
I need to do some research on what it takes to install a short throw in our cars and not mess up that whole "reverse/lockout" thing.
Thanks for the suggestions guys ---
alwayscode390 is offline   Reply With Quote
Old 01-14-2013   #26
WVZR-1
To retain the "lift ring" see the second option this link:
http://www.zfdoc.com/S6-40ShifterOptions.htm
Old 01-14-2013   #27
alwayscode390
Now that helped a lot
You just reuse your stock lift-ring, and stock knob ... then use the short throw shift lever you purchase from them?
Do any of these setups actually include the "gate" too , so the gear changes feel closer and more notchy ... or are they just shorter levers?
Sounds easy enough ---
Old 01-14-2013   #28
WVZR-1
Installed is a stock lever with "HURST" ball - mine has the "HURST" branding. If the ball is installed less the locking nut it seems to equate to a lever of maybe a bit more than 1" shorter than OE. Suits me!
I've a KWR modification package and the install CD that I've never gotten around to and a Hurst "take-out" with only a few hundred miles that a fellow just didn't like. I exchanged a late "crash-thru" stock to him. I might be offering these for sale soon.
Old 11-26-2013   #29
Karl
Karl's Avatar
B&M came with the car and I like it.
Old 11-26-2013   #30
Kevin
Kevin's Avatar
stock, no need to change it
