Old 07-28-2011   #21
Default Re: newbie injector question
Originally Posted by NWPzr1 View Post
I'm a newbie myself. I just ordered 16 rebuilt FIC injectors for a customers 1990 zr1. They said nothing about the primary or secondaries being different, and now I'm hoping they're sending me the right ones! I've heard nothing but good things about their customer service and honoring warranties etc etc... fuelinjectorconnection.com
I've seen others have good experience with them, anyone know if this is something to worry about?
Thanks
No worries!
Old 07-28-2011   #22
Kevin
Kevin's Avatar
Originally Posted by tomtom72 View Post
http://www.fuelinjectorconnection.co...&productId=208
These are the ones I would use if I were going to buy FIC injectors for my 90. I perhaps would give thought to the rebuilt FIC's if I wanted to save 1/2 the cash.
I'm trying to decide between the two myself. I like the savings on the rebuilts but i'm a little leery
Old 07-28-2011   #23
I have FIC Rebuilts, I had a couple leakers but were replaced fast for me..
3 years now no issues
Old 07-30-2011   #24
Kevin, please don't take my post as a knock on the rebuilt FIC's as it's not. I have to do my work Al Fresco. It's not worth it to me to spend less and have the chance I'll have to do the job over. I know that there is a chance that any part can be bad out of the box, new or rebuilt. I based my logic on the fact that the FIC rebuilds have had the odd leaker, also I can't remember any one posting about getting bad new injectors right out of the box.....it's more a decision of what circumstances I have to deal with if I want to do real work on my car.
Old 07-30-2011   #25
VetteMed
I'm very satisified with my FIC injectors, and happy I saved a few hundred bucks in the process.
Old 07-30-2011   #26
Kevin
Kevin's Avatar
I think i'm going with FIC and I'm torn between new and rebuilts. the extra $300 in my pocket would be nice but so would not having to rip apart my plenum again because they leak.
Old 07-30-2011   #27
ZR-1nce removed
ZR-1nce removed's Avatar
Tom, allow me to be the first that posted about bad ""new injectors out of the box. I installed the rebuilt ones from FIC and they were bad right away. We also had problems with a rebuilt set in Jims 93. I will give credit to FIC for their outstanding customer service because they overnighted me 2 sets of the new stainless ones. Once we installed the two new sets, we were back on track, but that was 4 injector jobs in 2 days. The extra money for the new SS ones are worth it....
90 ZR-1 #0951 Bright Red (sold)
06 Z51 MN6 Velocity Yellow (sold)
2023 C-8 Z51 ELB
ZR-1nce removed is offline   Reply With Quote
Old 08-02-2011   #28
NWPzr1
I installed 16 rebuilt FIC injectors on the 90zr1, and everything seems to be good so far.... It only has 10k miles, I threw some Lucas fuel system cleaner in the tank and trying to put some miles on the car. Although, I did get on it a few times up to 6-7k rpm and it seemed to run a bit rough after that in the lower rpm's for 10 min or so before I shut the car off. Then I went to start it up 2hrs later and it cranked for about 5 seconds before it fired and smelled like raw fuel for a few seconds. I've put some miles on it since then, but no problems have persisted. Thoughts?
NWPzr1 is offline   Reply With Quote
Old 08-02-2011   #29
Asking for guesses? Hmmmm.... I'm gonna guess one or more injectors is or was leaking. A fuel pressure leak-down test would be SOP for any new injectors. In fact, test can be done, and the injectors can be visually inspected before the plenum is reinstalled by hooking up the fuel rail and turn the ignition switch to ON and inspecting the injectors by looking down in the IH runners. Any fuel spraying or dripping, etc and you have your culprit/s. (I suppose you could poke a paper towel down below the injector nozzles to see if there is any seeping going on.) Then turn the switch off while monitoring fuel pressure at the Schrader (sp?) valve. It should hold to within a pound or two for 3-5 minutes w/o signs of leaking (dripping). I've done this before, and trust me, it is a lot easier to do than pulling the plenum to find a runner full of fuel, or hydra-locking a cylinder...
Just something to keep in the back of your mind, if there is no fuel leaking from the injectors, yet the leak down test is failing, I had a bad check valve in a newly installed fuel pump cause issues. My point being, testing the injectors before installing the plenum has many advantages, and you don't have to pull the plenum off (cuz it was not yet installed) to troubleshoot. Just a thought.
And, another thing...if that "injector cleaner" loosens something between the fuel filter and the injectors, where is it going to go? Any fuel system (including the fuel rails) cleaning would be best done before the injectors were reinstalled, and by a more positive/aggressive method than a passive fuel additive, IMO. Flushing the lines and replacing the filter(s) before installing the injectors...would be what I would prefer to do (but that's just me).
P.
Old 08-02-2011   #30
scottfab
scottfab's Avatar
Since you asked for thoughts and not guesses, here goes. I think there's no sense in worrying about what you could have done because the 90 has no exhaust valve seals. Oil leaks down into the combustion chamber and after high rpm runs will run a bit rough till it clears out. Mine does. So unless your engine has had seals added I'd suspect that. Try hard runs at 5-6k and see if it has the same symptoms. Mine runs fine at those rpms. Fist time I get into the heads the seals are going in.
Scott
