Old 09-01-2009   #11
Default Re: bad stutter at 2000 rpm, only power key on
Originally Posted by Spanky1965 View Post
I agree, but can you test the secondary actuators without removing the plenum?
You can peer in between the runners and watch them open.
Old 09-01-2009   #12
Spanky1965
how without starting engine?
Spanky1965 is offline   Reply With Quote
Old 09-01-2009   #13
Jeffvette
Jumper pin C17 on the ecm harness to a ground with the key on.
Old 09-01-2009   #14
Kb7tif
Pink wire. Have you ever had the plenum off? On mine that was all working and the Secondary throttle linkages were broken off even though the actuators were working, the plates stayed closed-
Kb7tif is offline   Reply With Quote
Old 09-02-2009   #15
OK...I corrected my previously assumed location of pin C17. My screw driver (I am assuming) is now pointing at the corrected location (that wire is pink with black strip on my 1991)
Thank you tccrab for the information
What are the pinouts for the ECM (which ECM is it?) for a 1991 ZR1
Old 09-02-2009   #16
tccrab
tccrab's Avatar
How to check the secondary actuators without removing the plenum:
http://www.zr1specialist.com/HAT%20W...0Operation.pdf
Lots more interesting and useful reading at Marc Haibeck's website:
TomC
"Crabs"
Old 09-02-2009   #17
Spanky1965
thanks guys, lots to check out
Old 09-03-2009   #18
Spanky1965
OK, by grounding the pink wire with the black stripe I popped the ecm fuse and car does not start...LOL
Old 09-03-2009   #19
Jeffvette
You hit the wrong wire then.
Old 09-03-2009   #20
Spanky1965
duh...LOL (just kidding)
