Old 09-13-2009   #11
billybaloneey
billybaloneey's Avatar
Default Re: Bought A 94 LT5 With Known Problem
Progress Pictures Part 2:
Head exposed & lifters removed -
Breaking loose head bolts -
Head Bolts awaiting removal -
Cams, lifters and head bolts removed -
A look behind the front engine cover -
I can't figure out how to remove the heads after the 10 head bolts have been removed from each side. I have tried tapping the head with a rubber mallet, I tried gentle prying with a screw driver. I have gone through the service manual and I can't find any reference to any special head removal procedure.
Anyone out there have any tips on getting the heads removed? I'm suspecting there are dowel pins (guide pins), does anyone know where they are located on the case/head?
billybaloneey is offline   Reply With Quote
Old 09-13-2009   #12
Jeffvette
There are two dowel pins. Use a bigger rubber mallet.
Also just remove all your wiring harness and fuel rails. It'll just get int the way.
Old 09-14-2009   #13
phrogs
phrogs's Avatar
Don't tap it with the rubber mallet wack it with the mallet kinda under and up just like jeff said there are dowel pins stick up a little over a 1/4 of an inch over the base of the block.
You'll see give it a good wack don't be afraid you wont hurt it.
Hard to see in this picture but I love it
JOHNNY P
Currently own
Old 09-14-2009   #14
4DSZR1
4DSZR1's Avatar
Great pictures, documenting your tear-down. I enjoy and appreciate you taking the time to post them.
I was wondering if anyone knows what the "1040" written on the front of the block means???
Rick
4DSZR1 is offline   Reply With Quote
Old 09-14-2009   #15
Polo-1
1040's were know to leak water. These motors were built right after break time, on the line.
Old 09-15-2009   #16
tf95ZR1
tf95ZR1's Avatar
Rick
Tomorrow is Tax day. Tax Form 1040. Reminding you to pay up.
Old 09-15-2009   #17
Pete
Pete's Avatar
The fixed chain guides are bolted to the heads,one on each side.
There is 1 plug in front of each head (13mm) take those out and you will see the 10mm screws.
When your ready to remove the heads make sure you don't bumb the plastic guides while removing the heads you can break them.
Don't ask me how i know.
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 09-19-2009   #18
billybaloneey
Engine damage update #1
I managed to get the heads off today and got a first hand look at the damage. Before I got the heads off, based on the #5 spark plug and #5 exhaust port, I thought the problem was going to be on #5, and sure enough thats where the damage was.
#5 cylinder liner and piston damage:
Old 09-19-2009   #19
Kb7tif
Damage to head?
Kb7tif is offline   Reply With Quote
Old 09-19-2009   #20
billybaloneey
Engine damage update #2:
#5 combustion chamber and head gasket damage -
The head gasket remains in place just as it appeared when the head was lifted off of the block.
All four corners of the combustion chamber show some damage
The gasket on top is from the other side of the engine is is used for comparison...close inspection shows the beginning of gasket failure (cracks and rust)
#5 is on the right, #7 is on the left
The area around #5 got so hot it melted several of the plastic secondary assembly connectors:
Engine experts - I have several questions:
1) are stock pistons and cylinder liners inter-changeable from '91 to '94?
2) the combustion chamber damage...can it be welded/repaired?
3) there is no visible valve damage...but to be on the safe side I might change them out...are stock valves (intake and exhaust) interchangeable from '91 to '94?
