Old 03-23-2009   #11
gbrtng
gbrtng's Avatar
Default Re: Maxton Mile Speed?
Altitude affects speed - Texas Mile stockers are around 155 at about 400 ft above sea level. Next biggest effect is ambient temperature.
http://www.texasmile.net/results/Oct...leResults.html and look for car 107.
That ZR-1 is mildly modified with Vette Drs top end.
Old 03-24-2009   #12
DMark
DMark's Avatar
Figure 150 + or - a few. Modded with porting and headers figure high 150's
Well since that Pirate up in BG got ahold of my Beast and did his topend porting along with SW headers, I reckon to be over the 150mph limit where the ECTA requires fullup safety stuff.
Dang...., and I just got the Bose all fixed up for the Delightful & Wonderful Mrs Kari (She Who Must Be Obeyed) to listen to. Hate to pull all of that stuff out to weld in a rollbar.
I wonder what would happen if I showed up and Oops - - - "Didn't know that old C4 would go that fast!"
DMark is offline   Reply With Quote
Old 03-24-2009   #13
Love that "she who must be obeyed"!
Ya could always just do that "ooops, darn she's just stock. Didn't think it could get that fast in a mile? Da ya think them headers did that?"
Old 03-24-2009   #14
jonszr1
jonszr1's Avatar
ah what the heck give it a try. its kinda ;like going 11.30 at the strip without a roll bar you go opps and they say by by till you get a bar
Old 03-24-2009   #15
tf95ZR1
tf95ZR1's Avatar
For Las Vegas, the under 168mph category does not require a roll bar
for a non-convertible. I think a bolt on harness bar was sufficient.
Check out your local rules before you go cutting your car up (unless
the wife just wants a roll bar!).
Old 03-24-2009   #16
PhillipsLT5
PhillipsLT5's Avatar
Yes, altitude, Vegas is at least 1,000 above sea level as is Phx
Could run 3 to 4 more MPH at sea level
You will have to go thru tech
Old 03-24-2009   #17
DMark
DMark's Avatar
Originally Posted by tf95ZR1 View Post
For Las Vegas, the under 168mph category does not require a roll bar for a non-convertible. I think a bolt on harness bar was sufficient. Check out your local rules before you go cutting your car up (unless the wife just wants a roll bar!).
Heck I just pulled the rollbar out of my Beast last spring. Still wouldn't have been enough for the ECTA rulebook.
http://www.ecta-lsr.com/rules/2008Ru...ndum032308.pdf
"..... All cars in competition over 135 MPH, must be equipped with a roll bar or roll cage structure. All closed cars between 135 MPH and 150 MPH must have a 4-point roll bar. All closed cars between 150 and 175 MPH must have a 6-point roll bar. All closed cars over 175 MPH must have a full roll cage....."
Oh well - - - The wife does like Vegas...., maybe I should head West instead of East.
Old 03-25-2009   #18
RedSled
cool.
RedSled is offline   Reply With Quote
Old 03-25-2009   #19
RHanselman
RHanselman's Avatar
Las Vegas (Nellis AFB) is at 1840'
There were 5 ZR-1's and the slowest was 156.4.
The results are posted here:
http://www.openroadracing.com/html/2008hrms.html
Cheers,
RH
Ron Hanselman
Founding Member #80
CM Lifetime Member #1093
1991 #383 Twin Turbo
1993 #099 Ruby, Jeal 368 w/Snake Skinner body
1961 White with Red Int
RHanselman is offline   Reply With Quote
Old 03-25-2009   #20
DMark
DMark's Avatar
Originally Posted by RHanselman View Post
..... There were 5 ZR-1's and the slowest was 156.4......
Hmmmmm...., Those cars are strong! I wonder what Mods are on them?
