#11 | |
![]() Join Date: Mar 2010
I hear you on the smoke and condensation, but fortunately, I have my 91 to compare to and in the same conditions, it produces no noticeable smoke or condensation, whereas the 92 is VERY noticeable. Clunk/click only happens going back and forth. Just based on their age, I'm planning to replace the bushings when I can. Thanks for your thoughts! John
1992 #043, Aqua/Gray 40k miles |
#12 | |
#13 | |
I've been thinking about sending the car to Haibeck for an overhaul and engine refinishing, but I want to gather much more information before I commit to that kind of time and expense. I've only done limited research on Marc's services so far...I'm assuming the housing and gaskets would be inspected/replaced if necessary? Thanks for the valuable info, John
#14 |
![]() Join Date: Sep 2008
1- pull the plugs
2- look at the plugs 3- one or more will be black 4- replace the plugs 5- ONLY AFTER you replace the Injectors With as much carbon and soot you are showing, it looks like your injectors are dumping fuel. Likely failed due to alcohol as they are pre 93. Your ZR-1 requires basic maintenance including plugs and injectors. It is 28 years old. I would also agree with an earlier poster that you also likely have leaks at the injector housings, but start with the simple stuff, if injector replacement resolves the issue, stop there. If not; then have a round two. ![]() Marty |
#15 |
I have a set of injectors up for sale currently, they are accel 21 lb injectors that already have the secondary nub filed done, so they are ready to install with all O-rings -
the injectors are a number one issue with the 90 - 92s. https://www.zr1.net/forum/showthread.php?t=32652 Just an FYI John |
#16 | |
#17 | |
#18 |
#19 |
BTW, the LT-5 does not use a Mass Air Flow sensor. It is a Speed Density motor w a MAP sensor.
#20 |
![]() Join Date: Sep 2016
Jkruz, I can take care of your under plenum needs. Send me a PM with your contact info and we can talk.
