Old 03-03-2007   #11
Jeffvette
Default Re: are there two different trans in zr-1's
Originally Posted by zr-1assassin
$1240.00-JUST TO PUT IT IN! does someone know what this SHOULD cost to have the clutch installed. no flywheel-just ACDELCO clutch kit i have? thanks guys
Should be 6 hours maybe 7 at most. It is rather time consuming.
Undo shift knob and other interior trim
Remove exhaust
Remove driveline
Remove C-beam
Remove trans
Remove clutch slave
Remove bellhousing
Remove pressure plate and clutch disk
Prep and clean surfaces
And install.
Old 03-03-2007   #12
Jeffvette
Originally Posted by Aurora40
No, that never happened. There were earlier Corvettes that had a 4-speed with a 2-speed overdrive, but not by the time the ZR-1 was on the scene.
4+3
4 speed with 3 gear OD.
Old 03-03-2007   #13
Aurora40
Aurora40's Avatar
Originally Posted by Jeffvette
4+3
Right, well the OD was a 2-speed overdrive, as in it had two ratios. It resulted in 3 extra overall gear ratios though (as it wasn't used on 1st gear).
