Old 12-06-2017   #11
ghlkal
ghlkal's Avatar
Default Re: What winter projects are you planning for your Beast?
7. Upgrade front J55 calipers to 96 GS calipers and probably front pads
I'd like to do this also, but I have a hard time finding reasonably priced GS calipers.
GC, do you have the calipers already?
1990 ZR-1 #2180 Red/Black
Many of the usual mods for 460HP, tuned by Marc Haibeck
ZR-1 Net Registry Member #1548
Old 12-07-2017   #12
yep bought months ago
Old 12-07-2017   #13
DRM500RUBYZR-1
DRM500RUBYZR-1's Avatar
Completely replace my valve stem caps; not just one, but all four of them.
The car is up on the lift so this seems like the ideal time to tackle this job that I just keep putting off.
Might also try to clean the entire inside of the front windshield if the winter turns out to be long.
Move the box with the now 3 year old new B&B Fusion Exhaust to the other side of the garage.
Whew......
Marty
Old 12-07-2017   #14
Mystic ZR-1
Mystic ZR-1's Avatar
Marty
Don't overdue it....
Old 12-07-2017   #15
JThomas
JThomas's Avatar
Joe,
I suggest the new radio route. If you were going NCRS then stock. But you have changed the color.. go aftermarket. The Sony XAV-AX100 is a nice unit and the XAV-AX200 adds DVD player and SXM. Both have Car Play and Android Auto capability
Thanks for the suggestions. I will look into those units. As much as I like my music, I have to be honest, whenever I drive the ZR-1, I am usually listening to the "music" made by the motor! I have only turned the radios on in the other two, just to make sure they even worked!
Joe Thomas
Corvette Club of Michigan
NCRS-Michigan Chapter Member
NCM Master Ambassador
Former NCM Board Member
1991 ZR-1 Melon Copper Metallic/Black
1992 ZR-1 Bright Red/Black (Sold)
1995 ZR-1 Bright Aqua/Gray (Sold)
2012 ZR1 Super Sonic Blue / Dark Titanium
JThomas is offline   Reply With Quote
Old 12-07-2017   #16
BigJohn
BigJohn's Avatar
Marty
You know if you sold me your sunviser I could put it on my 38 chevy.
Old 12-07-2017   #17
Zrracer
Originally Posted by JThomas View Post
1. Continued cleanup
2. Track down small oil leak
3. Shop for a new radio or upgrade factory unit with modern specs
4. Purchase new glass roof
5. Sort out minor height difference in rear end (Rear spring?)
6. Install new bearings in left headlight, so it rotates smoothly
Make sure you are measuring heights from the frame not the wheel wells.
Zrracer is offline   Reply With Quote
Old 12-07-2017   #18
Will get done
24lb injectors
Successful Nitrous Run
Would like to get done
New hard brake lines
C6 Calipers
Mufflers
Old 12-07-2017   #19
jss06c6
Originally Posted by Ccmano View Post
Just finished...
Flywheel Fidanza, clutch disc, pressure plate, pilot & throwout bearings
Clutch master, slave & steel braided line.
Drive shaft U-joints and C-Beam Plates
Hurst Shifter
Engine mounts
Oil temp & pressure sensors
Power Steering hoses
Headers, Obx Exhaust & new O2 sensors
Front shock bushings
DIC panel replacement
Instrument pod trim replacement
Moving forward she will need a tune (Dom you listening)
Driver seat transmission replacement
Fix the tach (usual incorrect readings)
Alignment
Not sure for this winter but if time and funds permit
Replace all suspension bushings
Port the plenum and injector housings plus power coat.
New carpet.
It’s an on going project...
H
Hans,
How does she run?? Congrats on the progress buddy!!
Steve
Old 12-07-2017   #20
jss06c6
Whew......
Marty
Now that's a good list!!
