Old 12-15-2016   #11
DRM500RUBYZR-1
DRM500RUBYZR-1's Avatar
Default Re: Sticking Brakes
Originally Posted by We Gone View Post
Have you ever changed your front brake lines? I had an issue the same as you it was the inside of the front lines had gotten soft and were collapsing not letting the fluid go back to the master cylinder. As soon as I released the pressure by opening the bleeder on the caliper it released.
I agree.
That would be my first suspect!
Explains the locking of front only.
M/C usually would affect all 4 the same.
The "cooldown" that fixes things might be a slow bleed off of the pressure, which could also point back to the M/C or the relaxing of the faulty hoses.
I would suggest switching to braided stainless lines on all 4 wheels as a good starting point, after inspecting all 4 calipers and lines for leaks.
Keep us posted on progress!
Marty
Old 12-23-2016   #12
jss06c6
What did the pros come up with?
Old 12-23-2016   #13
Old 12-24-2016   #14
USAFPILOT
USAFPILOT's Avatar
still waiting
Old 12-24-2016   #15
george1945
I would look at the master cyl. And ABS
george1945 is offline   Reply With Quote
Old 01-26-2017   #16
USAFPILOT
USAFPILOT's Avatar
Turned out to be sticking front brake calipers, pistons not returning caused by really really dirty old brake fluid. So, rebuilt calipers, fresh double flush of the system and the old girl is back in business. Well, on to the next problem anyway.
Old 04-14-2021   #17
staminqia
staminqia's Avatar
When you had this issue was your brake light on the instrument cluster flash on and off while driving? I have a similiar issue with rear brakes slightly sticking and I know brake fluid looks pretty dark. I am wondering if I have a similiar issue.
staminqia is offline   Reply With Quote
