Old 06-28-2016   #11
Chris26
Default Re: Fuel pump hotwire
Thank-you for everything BTW!!!!
Where is the relay located???
I will check connections on the pump assy. In the tank
Chris26 is offline   Reply With Quote
Old 06-28-2016   #12
OK...some legitimate logic here... IF there is (as you indicated) 6+A with both fuses in place, we can assume that both relays (w/ ignition OFF) are not the issue: To have 6+A w/ FP1 and FP2 inserted, the relays are in series, i.e., current in series is common to all circuit components in series.
Next, I would "divide and eliminate": see what you have at the fuel pump connector. Note: Before going further, do NOT expose fuel vapors to the potential of electrical sparks - especially when making voltage measurements with an open fuel tank!! (Course you know that, but you might not be the only one on the internet reading this!)
If it is good there, then check resistance of both pumps, measured between the input power and the ground. Also, inspect both halves of the connector.
Old 06-28-2016   #13
Chris26
Not worried about fuel vapor and sparks....I live in front of a fire station!!!
Old 06-28-2016   #14
Chris26
These are my two readings...
16.7 ohms
3.1 ohms
Hmmmmmm......
Old 06-28-2016   #15
Chris26
Ignore those readings they are just an anomaly...
The connectors are corroded due to water that was in the tank.
Old 06-28-2016   #16
Good job. Now, when the connector is cleaned up and sealed, is the resistance through the pumps more or less the same? If so, button it up. But, now go back to step (one) and measure current w/ the key off. It should be between 8-10A at the pump prime connector, yes?
Old 06-29-2016   #17
Chris26
Pumps put out 6.17a under load with gas and 2.70a pumping dry.
they both read about the same...they seem like replacement delco units from 2014.....All contacts were cleaned thoughly ....crud and water at the bottom of the tank....first offer of 7k CDN takes this puppy home( sans water in the tank)..
Got my order in from Jerry's today...
Old 06-29-2016   #18
G8nightman
G8nightman's Avatar
Selling the car for 7k?
90 Chevy ZR1 LPE #2315 'SOLD'
90 Chevy ZR1 LPE #2774 'SOLD'
91 Chevy ZR1 #1512
91 Chevy ZR1 #951
95 Chevy ZR1 #338 'SOLD'
91 BMW 850i
94 BMW 850csi
95 BMW 850csi
94 Lotus Esprit S4
07 Benz CLS550
06 BMW M5 "SOLD"
G8nightman is offline   Reply With Quote
Old 06-29-2016   #19
Chris26
In a sarcastic and somewhat sadistic way yes!!!!....I just don't have the resources or time for this project....
Old 06-29-2016   #20
G8nightman
G8nightman's Avatar
Post some pictures of the car..
91 Chevy ZR1 #1512
91 Chevy ZR1 #951
91 BMW 850i
94 BMW 850csi
95 BMW 850csi
94 Lotus Esprit S4
07 Benz CLS550
06 BMW M5 "SOLD"
