Old 05-02-2015   #11
Default Re: Tuning
Jeff,
I've looked at the auah bin w both 8E and 8EA. The correct mask is EA. Would you send me your .xdfs and bin files for the 90? Which is the broadcast code for the $8E bin?
Old 05-02-2015   #12
Default Re: Tuning
Yeah I can.. need to find where I moved them to.
Old 05-02-2015   #13
ZR-1
Default Re: Tuning
I'm still not able to get download from the gearheads website. Says I need to verify but I never received the email for it..
Anyway, there are 3 things that show up in tunerpro rt that I was trying to clarify. adx, xdf, and bin.
Is it possible to grab the tune from the z-industries chip I have?
ZR-1 is offline   Reply With Quote
Old 05-02-2015   #14
Default Re: Tuning
Yes using the APU BUT you need a 28 pin header like this to read it into the APU and then save for TPRT.
The bin is the binary file, the .xdf is the definition file, and the adx is the ALDL datastream
Old 05-02-2015   #15
ZR-1
Default Re: Tuning
Thank you. Much appreciated. Will see how far I can get with it this week.
Old 05-03-2015   #16
Default Re: Tuning
BIN - file stored in the MEMCAL.. gives your car a brain for the ECM
XDF - definition file so you can make sense of the BIN
ADX - used to capture data through your ALDL link.
if you use android there is a nice datalogger ALDLDroid) works great with my 90 Z
Old 05-03-2015   #17
ZR-1
Default Re: Tuning
I'll be using a laptop but do have a tablet as well..
Is there a program that helps to tune the tables available for obd1?
I was looking at the flash n burn program and it asks for addressing. Not sure why I didn't get any instructions with this program.
Old 05-04-2015   #18
ZR-1
Default Re: Tuning
I was able to make the adapter to copy the z-industries chip. I used both 8e adx and 8e xdf to read and write the chip. I appreciate all of the help guys!
Old 05-04-2015   #19
Default Re: Tuning
Tune which tables?
What exactly do you mean by 'helps'?
Old 05-04-2015   #20
ZR-1
Default Re: Tuning
I suppose the ve tables. I've used a program before on obd2 that made calculations and adjustments while I drove. It was a breeze.
