-   -   Tuning (http://zr1.net/forum/showthread.php?t=25007)
ZR-1 05-01-2015 04:14 PM
Tuning
I ordered the apu1 tuning kit through moates.net and when I went to pull my memcal today it says z-ind race program. Is it still ok to piggyback this chip with the g1 adapter?
XfireZ51 05-01-2015 06:04 PM
Re: Tuning
Yes. But you'll need a calibration for the APU to run the motor with. So you should read the cal off the Z-IND prom and download it into the APU for emulation. You'll use the APU to read the cal but in order to do that you need header pins to insert into the prom and then place it into the APU. Also need TProRT
ZR-1 05-01-2015 06:06 PM
Re: Tuning
Great. This tunerpro/obd1 tuning stuff is much different than the obd2 plug and play stuff im used to.. I'm now trying to figure out the bin and definition files. Any input on that? 90 zr-1 1228331 auah
ZR-1 05-01-2015 06:10 PM
Re: Tuning
I guess I need an explanation on specifically how to get started. I know how to tune, just no instructions really on how to get everything ready I suppose.
XfireZ51 05-01-2015 06:29 PM
Re: Tuning
Pick up the $8E and $8EA definition file. Need make sure ur using the right mask. Load the bin file into TP, then the Mask, then read the either the
Injector # or cylinder volume. Injectors should be 22.8 and the cylinder volume is.71. Don't save bin using wrong mask.
ZR-1 05-01-2015 06:44 PM
Re: Tuning
I guess my problem is finding the auah bin? The 8ea is almost impossible to find. I found it on a gear head website but had to register to download it. That was 3 days ago and still no confirmation email.
XfireZ51 05-01-2015 06:46 PM
Re: Tuning
PM me ur email. I'll send you the mask and bin file. =Jeff= has it also.
ZR-1 05-01-2015 07:56 PM
Re: Tuning
PM sent. Again, the help is much appreciated!
-=Jeff=- 05-01-2015 11:07 PM
Re: Tuning
Sent you a PM as well.. You PM'ed me on gear head but I did not get to reply.. you should have access to stuff there though
Anyway.. Where in Illinois are you?
HAWAIIZR-1 05-01-2015 11:14 PM
Re: Tuning
Hey Guys,
I can't wait to learn this stuff myself one day. It sounds like a foreign language, but I know this is key to getting individual cars running just right. This would be an awesome workshop to have at the Gathering one day. "Tuning 101"
Aloha,
