Old 04-03-2014   #11
Default Re: Ride control question
The oil cooler is sandwiched between the rad and ac condenser, follow the lines to the connection at the cooler has two line with a single bolt to the connecting block it is replaceable as a set,
http://www.ebay.com/itm/like/291012080282?lpid=82
Steve
1990 Steel Blue/Black #2355
1990 Red/Red #1473
1991 Quasar /Black #118 Sold
1993 Yellow/White #179 Sold
Old 04-03-2014   #12
90ZR1#1221
I just looked at my lt5 service manual on how those lines ran and it looks like if they're leaking at the oil cooler it's going to drip down onto the coolant lines.
90ZR1#1221 is offline   Reply With Quote
Old 04-04-2014   #13
scottfab
scottfab's Avatar
The most common point of leakage on the OEM hoses is at the connection ends where the metal contacts the rubber hoses.
Scott
Old 04-04-2014   #14
Found it! Two leaking hoses running to the oil cooler. Apparently the age and for how long the car was sitting before I bought it have took its toll on some hoses. Looks like a pretty easy fix. Any recommendations on where I can get some good OE hoses and clamps without having to go to a dealer and does anyone know if there's a parts/service manual I can download for this car?
Make sure you have the right wrenches handy as those fitings are over an inch in size. if I remember correctly 1-1/8 and 1-1/4 are needed. Those sizes are not in everybodies tool box. I suggest the steel braided replacement option.
Old 04-21-2014   #15
90ZR1#1221
Put new oil cooler lines on. While it was apart replaced the lower radiator hose it was really spongy and seeping. Got everything back together no more leaks. The car runs great. The service ride control light went off on its own but now my change engine oil light is on. Is there an easy way to turn that off?
Old 04-21-2014   #16
scottfab
scottfab's Avatar
Scott
Old 04-21-2014   #17
Owners Manuel 101,
Key on
press ENG/MET with in 5 sec press again
within 5 sec press & hold range button Change oil light will flash
Hold range button until is stops flashing.
Steve
1990 Red/Red #1473
Old 04-21-2014   #18
edram454
edram454's Avatar
Once you move the car the code will clear. It has happened to me several times already.
Old 04-21-2014   #19
90ZR1#1221
Much appreciated!
