Old 10-18-2013   #11
Default Re: Alarm question.
Originally Posted by QB93Z View Post
I had symptoms similar to what you are describing on my 1994. The switch that tells the CCM that the door was unlocked with the key is inside the door, behind the door handle. In the manual it is called the Anti-theft Switch. If the CCM doesn't get the "key unlock" signal from that switch before the door open signal is seen, it sounds the horn. The door open signal comes from the door ajar switch. The door ajar switch located in the door edge and visible with the door open. It is a different switch than discussed above.
Here are some pictures of the door handle and switch:
It is a challenging job to take the door apart to replace that switch, but it can be done.
If you need a step-by-step, let me know. I just replaced it last week, and it solved all my alarm problems.
I got the switch (used) from CorvetteNutz.com.
Jim....I for one would like the step-by-step as all doors are a bit different (nice photos Jim) .......
I am assuming the anti-theft switch cannot be taken apart and fixed in some way?
Thanks Jim......and yes.....I have purchased parts from CorvetteNutz many times
Dynomite is online now   Reply With Quote
