#11 |
I did clean the throttle body Thoroughly but the thing that bothers me is that it did this before I did anything in fact it was worst.
Dave |
#12 |
Did you remove TB when you cleaned it? If you have a scantool, check the TPS v
with Ignition ON. Surging of the LT-5 is common when idling down in neutral and slowing down. This can be mitigated by flattening the Spark and VE tables in the "Idling zone". I also change the IAC setting so the idle stays a bit high until it reaches Idle MPH. First thing is to determine there are no technical issues. I would look at the IAC counts at idle. Maybe MIN AIR needs adjusting. |
#13 | |
![]() But Marc sent me a new 90' chip so I expect now a normal and immediate idle under all conditions ![]()
Clickable links ![]() On Iphone Touchable Links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 06-28-2013 at 12:16 AM. |
#14 | |
Yes I did.
Dave Quote:
